A new one for me |
Post Reply ![]() |
Page 12> |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21832 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Dec 2021 at 5:10pm |
8050 with approx. 5,000 hrs had a #6 exhaust seat fall out of the cylinder head, destroying the piston and badly damaging the head. Got the head welded up and completely refurbished and while running the valve tappets, something wasn't quite right with number six intake. Still had the oil pan off from replacing the piston and sleeve. Took a quick look at the camshaft and holy crap, the lobe to #6 intake valve is totally wiped out !! When tearing the head off of it I didn't pay any attention to the valve lash on any of the valves, but I assume the lash must have been pretty wide on that valve. I am concerned about the newer Rotella oil that has been used in it maybe not having enough ZINC for these older flat tappet camshaft engines. Got some more investigating to do before I pass judgement on this one, but this for me is a first. My theory is with the intake only opening about half-way that particular cylinder and it's exhaust valve have been overheating (no overlap), causing the valve seat to loosen and eventually fail. Engine had just finished dragging 600+ bushels of corn on a 5 mile trip and was shut down for the day. Next morning upon start-up things went south immediately.
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2377 |
That is an oddity. Don't normally see many problems with the head on that series of engines. And camshaft failure is almost unheard of.
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Please keep us updated on your findings and theories on this. I have wondered about the zinc content in rotella and wonder if we need to add zinc to the oil.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6066 |
Not second guessing anything, but my initial thoughts... Is there any way that the displaced seat could have either obstructed the valve, or prevented the lifter from rotating, causing destruction of the lobe? If the seat were to have come unglued FIRST, i.e. it cracked and then dropped... the valve would TRY to close, but stay full-on against the tappet because there was nothing ELSE to take the spring force away... and in many cases, that would prevent the lifter/camshaft surface enough relief time for the oil-film to recover for another pass (the lifter/lobe interface point being in a circumstance of hydrostatic shear... basically, floating on the film, right?) Was there any of the valve seat left for forensic exam? |
Exhaust seat is what fell out. Intake lobe is what is worn out, not damaged, just plain worn out. Not one bent pushrod anywhere. Lynn, this is a FIRST for me. Never have replaced a camshaft on any 2000 or 3000 series engines for lobe failure.
MikeKroupa ![]() Bronze Level Access ![]() Joined: 12 Sep 2009 Location: pierce,nebraska Points: 77 |
I've never seen one that did that. I overhauled one of my 3500 powerunits in the early 2000's that had 20k plus hours and the tapets showed some pitting so I replaced both cam and lifters. I'd reach out to Rotella Tech Support and see what their thoughts are, myself have been a Delvac 1300 user for 30 plus years, so far so good. I always thought that was a mid 70's GM small block issue. LOL, Mike
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3521 |
My 2 cents... we received a bulletin from our small engine mfgs years ago stating premature wear in camshaft/flat tappet due to the removal of zinc, selenium and copper from automotive oils which did not 'need them' due to roller tappets. The small engine oils received a permit to include the "pollutants" and still have them . We noticed the new Agco engine oil for tier 4 engines had many less additives as it seems IV rotella has as well (they charge more for less additives) . I do not think the oil caused this issue as if it were the oil ALL the lobes would show wear - but I do worry long term as Al gore and his environmental minions strive to save the universe and make our old stuff suffer in the process.
My concern is the forced lowering of zinc levels by our government, for the newer engines and their emissions systems. The newer engines have roller lifters which can survive with less zinc. These older engines may not and this could be the first casualty that I have just seen.
https://www.vitacost.com/dr-mercola-zinc-plus-selenium?
Hmm one can buy zinc plus selenium vitamin supplement --- but they won't let it in oil...
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1488 |
Valvoline still has some zinc in their racing oils. I wonder how they are still able to do it? Now they do have a disclaimer. Not legal for street use or something silly like that. But it sure is expensive. About $100 Canadian for 8 litres. Not diesel spec so wouldn’t help you guys.
Edited by Ed (Ont) - 23 Dec 2021 at 10:10pm |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8706 |
my dad had the same concern. I recall him trying to call some oil companies with this concern. I’ll have to ask what they ever did say.
When looking at oil, how many ppm is good. Or is there additives out there for that. Edited by Mikez - 24 Dec 2021 at 6:12am |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8612 |
you can buy a zinc additive for engine oil but I don't know if something you pour in is same as "made with it"
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5086 |
My understanding is that the "Shell Rotella" With the "T4" designation meets the older spec for flat tappet cams. However the newer spec T5 & T6 oils do not. I use the T4 oil as well as The "AMSOIL" Diesel Marine oil and have not had any problem with tappet wear yet. Amsoil also has an oil for gasoline engines that has the name Z-Rod, specifically designed for flat tappet camshafts in older vehicles.
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10866 |
You can buy oil with Zinc they label as breakin oil, on my 1975 Ford 390 I am running this oil all the time, I don't run the truck that must but want to be safe.
pirlbeck ![]() Silver Level ![]() Joined: 01 Dec 2009 Location: West Central IA Points: 229 |
Back when the CI-4 oils were "upgraded" to the API CJ-4 spec I did a lot of reading about the changes in the oil additives. The beneficial additives that were removed were commonly referred to as ZDDP. At the time the oil company "experts" were claiming that while yes they removed the ZDDP there were other additives and changes made that replaced the ZDDP. My thoughts at the time was what if 5-10-15 years down the road we find out that these "experts" didn't know what they were talking about and all of sudden we had a lot of oil related failures, mostly flat tappet camshaft and lifter wear. As I have mostly older diesel engines (2006 Dodge Cummins, 8.3 Cummins in combine and tractor, 8.1L Deere and 4 diesel garden tractors) I had a real concern about this and so far I have been able to source a CI-4 Plus oil from my oil supplier.
I am not sure how long it is going to be available, but I very recently purchased 2 barrels of it.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Best odds for cause of loose valve seat is overheating. So leaky drip injector problem or exhaust valve not closing fully. Coolant issue. It was cylinder #6, huh. The last cylinder. Best odds of a single lobe to be wiped out is tappet not following the lobe, slapping down on the lobe. Weak valve spring or valve sticking. Or lack of lubrication to that lobe. So when you have both problems in the same cylinder the sequence of events is thus... Sorry, come on, do you guys think I am smarter than the doc? If the intake lobe is worn that cylinder doesn't get enough air. The injection pump doesn't know that. So the cylinder would run rich. And that means what for heat output? Oh the fun of mechanical contraptions. |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
I reached out to Amsoil and asked them if any of their products are capable of fulfilling the needs of these old tractors. I'll get back on here when I get an answer.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
I have saw a lot of worn cams, and cam followers, but most are worn about even across all. One being worn makes me think a soft lobe. Was that rocker arm trying to gauld to shaft? MACK
OK guys, here is what I got... Hi Ted, We do offer a Z-Rod 10W-30 that is made for older gas with flat
tappets and has a lot of ZINC in it. But we are not sure if that will
work. Because of the age of
your engines, it might be best to use a conventional oil with high zinc
in it since synthetics may expose any leaks or cracks in the engines
because of the high detergents we have in our products. No worries at all! A good diesel oil to use with a lot of ZINC would be our Heavy
Duty Synthetic Diesel and Marine Oil 15W-40 (product code AMEQT). It is
a very popular oil for older tractors. Thank you, Jake Siptroth AMSOIL Technical Services Tech Line: 715-399-8324 Email: tech@amsoil.com |
I'm waiting for my two oil samples to come back. One from the barrel of new oil and the other from the tractor that failed the camshaft. When I get the old cam pulled I can look at the other lobes more closely.
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1747 |
This is interesting. When I changed bulk oil suppliers, I wanted to make sure the ZDDP/zinc content in the oil was good for older flat tappet engines. The rep from where I buy now said the 15w40 engine oil that I use has 1000 parts per million of Zinc. I was hearing that the ZDDP could be as low as 600 ppm with new enviornmental restrictions. 1000ppm I consider good to use on these old tractors, especially when the valve spring pressure is stock yet.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
The Petroleum Quality Institute Of America They have tests showing things like zinc content. I don't see a clear trend towards reducing zinc (in the last 8 years). Exception that I spotted is Chevron Delo. 1490ppm then, now 807. However, the Delo has higher levels of boron and molybdenum. The tests go back to 2012. Nothing at all from the days our engines were produced. Maybe some of you guys can ask your oil testing tech's what the zinc level used to be circa 1975? I do remember reading that too much zinc could cause corrosion. But how much? Shell Rotella T5 has more zinc than T4 Most oils are from 1000 to 1250 ppm of zinc. Just looking at zinc levels doesn't seem right to me. |
I believe there's more to it than just zinc but am not schooled in that science.
allisrutledge ![]() Orange Level ![]() Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
I'd check the hardness of the Lobe on the low side and check the one beside it to see if it was a hardness issue. Strong chance there was a issue in the heat treat since this is a rare case. Hope you find something
Well, oil samples are back and to me are inconclusive. The oil sample I took from the failed camshaft engine was done differently because we had already drained the oil. So, I removed one oil filter and carefully drew old oil with a siphon tube from the center of the filter, which would be clean filtered oil. I thought this would be some what representative of the oil inside the engine. If there was truly a serious failure going on even the filtered oil should be high in iron. It isn't. Iron was 9 ppm, which is fine and doesn't indicate a camshaft lobe failure to me. Zinc was 1170 ppm which I believe should be acceptable for flat tappet camshafts. New oil fresh from the barrel shows 1123 ppm on zinc. So, I guess we throw a new camshaft and lifters in it and get on with life. Things happen. I suppose the cam lobe/lifter failure could have been a long time ago, as the current owner has only put 1,000 hrs on it in the last 10 years.
Just when ya get to the "gotcha" and throw open the door.....nothing there! You did your part so it becomes a shoulder shrug and move on....
Any more thoughts as to the cause, how did this end up? |
Got some pics on my phone. PM me with your phone number and I'll send them to anyone. Complete wipeout of one intake lobe and the beginnings of another.
Edited by DrAllis - 19 Mar 2022 at 7:43pm |
It is certainly perplexing. Not related in parts, but a somewhat parallel situation occur with a custom-grind camshaft that had just one lobe totally rub out just 80 hours after a successful break-in. We went back and did a D/T inspection on all the remaining lobes, and found that the hardening on all the ground surfaces was fine, except for one spot in the fuel pump lobe, which was right next to the failed lobe. Since the failed lobe was basically gone, our best guess, is that there was either a soft spot, or a THIN spot in the harder face, and it was just enough for the lifter to skid over that spot, rather than rotate... and once that started happening, it took the lobe out quick. Zinc, and all the other 'heavy metal' additives that go in will be a problem, as environmentalist pressures will devoid us of their benefit.
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
I have nothing of value to add but that was a very interesting read. Thanks
Post Reply ![]() |
Page 12> |
