6060 won’t move
Rafterg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Topic: 6060 won’t move
    Posted: 12 Dec 2021 at 8:13am
I have a 6060 that yesterday all of a sudden would not move. Seems to go into gear both high and low and all gears. Any thing I should take a quick look at that might be a simple fix that I am overlooking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 8:29am
welcome to the forum.
How’s the clutch pedal feel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 9:00am
Like it has since I have owned it. There is not much travel down below though. It seems like it does not have much resistance
Edited by Rafterg - 12 Dec 2021 at 9:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 2:22pm
So it goes into all gears with no grinding at all??? Are you sure the main transmission is really going into gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 3:08pm
I'm going to say the range lever (high-low) is in neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 6:48pm
So the high lo seems to be going into gear, is there a way to tell if it is stuck in neutral
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 7:22pm
Pin out of rear end?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 7:46pm
If the differential pin has fallen out, a quick test would be set the parking brake really tight. Try to move the tractor then. If it kills the engine, the differential area is the problem and quit trying to make it move!! to save on the damage.
Post Options Post Options   Thanks (1) Thanks(1)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 5:00am
Does it have pto ? From my limited experience the diff pin typically takes the pto with it when it backs out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 7:47am
The pto turns when turned on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 8:01am
TRY THE PARKING BRAKE !!! and see if it pulls on the engine !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 11:34am
That’s a issue I haven’t heard before, pin out of the pinion. Hope it’s not that. I would have guessed hi/lo in neutral also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 11:42am
Pin out of differential spider gears....can cause GREAT harm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 12:00pm
That’s an understatement
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 12:01pm
Shift lever broke off below the transmission cover? BTDT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 5:43pm
Tried setting the e-break and it did not kill the tractor. While it was started, I could shift the tractor with not having the clutch pushed. Pto engages
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 5:45pm
Problem is then clutch or transmission input issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 6:28pm
There are 2 dowel pins on the main shifter that do back out at the shifter base - check those
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 7:08pm
On the high low or gear. How do I access to see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 6:11am
In the main 1-4 transmission lever, take the rubber boot off to see
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 8:12am
not to change the subject. What other allis do you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 9:13am
With the engine running and the range lever in gear (low or high I don't care) foot OFF the clutch, you should feel gears grinding when trying to shift into 1 or 2 (non-synchro) and you should NOT be able to get the lever into 3rd or 4th. If you can, the input shaft must not be turning. Are you sure your clutch pedal is released?? The pedal should come up probably 6 plus inches from bottom with your foot off the pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 9:16am
dr is that cable for clutch pedal like 6080.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 10:58am
Last night I started the tractor to see if I could kill with the e-brake and it would not.  I then thought I would see if I could change gears without pushing in on the clutch.  I could move through all gears and hi/low with out anything happening or grinding.  It is like if the clutch pedal is pushed down and doesn't release.  When I go under the cab though, the clutch cable moves the arm that goes into the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 11:31am
And the clutch pedal foot pad moves a total of at least 6 inches or more top to bottom ?? And the resistance/effort required to depress down on the pedal is the same as it always has been ?????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 11:52am
Yes, that is correct.  The only thing that seems odd is the amount of travel down below.  Doesnt seem like a lot by I also now it does not take much travel to engage or disengage the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 5:44pm
is it moving the clutch lever on side of bell housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 8:34pm
Yes it is moving the lever on the side of housing
This page was generated in 0.961 seconds.
