What disc is it??
DiscoPaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Topic: What disc is it??
    Posted: 10 Nov 2021 at 4:37pm
Bought new new unassembled AC disc today. Listed as 14 foot. believe its a 10 footer. Tags on it have numbers 382180 on the frame, 32055 on a pan. looks like cement blocks would fit, and 82056, wood bearing 300627. 7 discs on each axle. 4 axles. about 4 ft wide.uploads/22596/disk22-1.jpguploads/22596/disk22-2.jpg new to this forum need to figure out how to post pics.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 6:16pm
Don't know what model that is, but  cool find ,whatever it is. And welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 6:34pm
Wood bearings, probably what is known as a WD disc, But it could be older than even that.  From those boxes, in the back of the steel picture, it might be a LaCrosse built 114 disc harrow.  If so, its a one way disc, all discs point inward, like the rear gangs of a normal disc, and is spread out pretty wide, in the only picture I have ever seen.  The picture I'm talking about is in Swinford's book, being pulled by a WC tractor...Wink
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 7:42am
I curious to see your new Allis Chalmers disk when you get it assembled and in the field operating. That is a great find. .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 10:41am
I will. Going to be one of my winter projects. Hope to get it unloaded today. Thinking about using a real light grease on the bearings over the winter. I'm sure the wood is pretty darn dry. Thinking it might soak in some.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 1:24pm
Very cool find!
That's a No. 9a Disc Harrow. I have a book in my drawer for it that I'm staring at as we speak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 1:26pm
Paul, you might try soaking the wood bearings in oil for a few days and see if it soaks some up.. Then when you install, use grease..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 5:35pm
You all ROCK!!!!!! Will do on the oil. Great to know what model it is. Gonna spray all the bolts tomorrow. Hopefully will loosen them up some.
THANK YOUSmileSmileSmileSmileSmileSmileSmileSmile
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 5:40pm
Was it in a wood box? Nice to see a picture of that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 5:42pm
I'm sure it must be an 8 Foot model. I knew it wasn't 14 foot. Can't wait to get started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 5:45pm
No on the wood box. It was on a implement lot. One of their customers put on consignment. Made them an offer and they took it. I think most if not all the parts are there. Maybe missing a couple of bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 5:48pm
Plan on repainting as I get into it. The disc's still had the edge protector's on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 6:04pm
That is a neat find.
Do you have any other allis
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 6:13pm
if it was mine I wouldn’t assemble it.  It will never be cool as it is now.  If you want one to use buy a used one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 6:44pm
1st piece of Allis. I just thought it would be a cool project. Thinking after looking at pics in manual it might be missing a part for the back. We raise grass hay and goats. Doubt if it will get used much. If at all. It was cool to find something so old still unused. It would be nice to keep as is.
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 7:09pm
I think it is a number 15 disc I stop one day and took a look at it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 7:15pm
Roger I'm not far from you.  Just outside of Cannon Falls MN. Looked at ebay listing that Allis Dave posted. Looks pretty much like the 9a. I'll take a look at the 15.
Everyday is a good day. Some are just better than others!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 7:18pm
Don't think it is a #15. All disc sections are just under 4 feet wide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 9:11am
OK so I just got it unloaded and looked at tags and manual on ebay. Numbers don't match up. I have 2 bundles each of 32056 and 32055. Those are the pan bundles with hardware. The frame bundle is 382180. Discs are 16 inch. The search continues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 1:02pm
It's not a #9 as the arched piece that pulls the tandem is not there.  I would say it's a single disc maybe a #15 as was previously stated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoPaul Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 7:41pm
I think Roger is right on the 15 foot disc. Found some pictures
Really want to thank everyone for their help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 6:25am
Personally, I wouldn't paint it. Tha'ts some good original paint. (And I usually like t paint things...)
