clutch alignment tool
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: clutch alignment tool
    Posted: 26 Sep 2021 at 9:05pm
I'm looking for an alignment tool for a 210 allis,would like to have one of my own if possible.
I'm in Indiana.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 5:41am
Some of the manuals show you a diagram of the tool so you can make it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 5:57am
shh, I used a broom handle,20 year ago and Troy's still happily running.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 6:23am
Jay, it's no secret. I did the same on a 170
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 7:17am
With a recessed flywheel, it caint be off very far.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 7:17am
Pretty sure the D21/210/220 takes the exact same tooling as any big frame Farmall from 806 and up.
Edited by DrAllis - 27 Sep 2021 at 7:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 8:12am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 8:30am
was told every 'clutch kit' is sold WITH the alignment tool, maybe hit local garage, see what they have...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 1:50pm
I just replaced both clutches in my 160, as Charlie said my manual gave me exact measurements for my local machine shop to make me one out of aluminum. $25, so much better than the plastic ones that can break or flex.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 3:56pm
This is my experience, and I always try to do things right- the clutch disc is so close to being centered- gently tighten the pressure plate bolts ; look from behind , and center the disc with a screwdriver or something like that in the pilot bearing - its very simple
Edited by DougG - 27 Sep 2021 at 3:57pm
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 5:09pm
Maybe I’m just lucky, but I haven’t used a clutch alignment tool for the past ten years, just eye ball them and slide the tractor together.
Good luck
if you need one you can make one out of wood on a wood llathe, unless extremely heavy clutch plate.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 8:41pm
That may work on a tractor with just a transmission clutch, I wouldn’t attempt it with a dual stage clutch such as in my 160. The clutches can’t take misalignment and will bend very easily. The entire clutch assembly weighs 70 lbs.
Edited by AC720Man - 27 Sep 2021 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 9:06pm
Finally got the MK II 3700 engine bolted up this morning on the 210
and did some painting.
I only have 3 days a week to work on it due to working 12 hour shifts
Monday-Thursday and have other things to do also but it's coming along.
This page was generated in 0.131 seconds.
