Timing WD45’s
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Timing WD45’s
    Posted: 15 Sep 2021 at 2:26pm
I got two WD 45’s new to me that I have completely changed fluids and tuned up I’d like to check the timing I think Doc said wide-open throttle but I just need to know what mark underneath thanks. Capt. Dana
Blue Skies and Tail Winds
                          Dana
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 3:38pm
Take inspection cover off underneath. Find your marks first and clean up with brake Kleen or whatever you want. Find and mark the “F” which is the fire mark. Check your point setting first. Make sure it is .020 as called for in the manual as that does affect timing. Hook up your timing light. Start engine and run at 3/4 or full throttle. Set your timing. That “F” mark needs to be right at the bottom in middle of inspection hole. There is an alignment arrow on housing in middle. You will see it if you clean everything well.
Edited by Ed (Ont) - 15 Sep 2021 at 3:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 3:43pm
You will need 6V timing light if it is still 6V system. Those are not always available now. I have a golden oldie that does 6 and 12 both just like the operator. Lol. I think that “F” mark is 30 degrees but not sure of that. Some one can clarify but just set it to the fire mark. 😀
Edited by Ed (Ont) - 15 Sep 2021 at 4:04pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 5:27pm
Awesome! Thank you! Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 7:49pm
Dana I forgot to mention. You may find two complete sets of marks on the flywheel. Clean them both if you want. Only the correct one will show with your timing light. Other one is for timing it from the top maybe on a stationary engine. WD45 has no access from top. Mine has two sets of marks. They are 180 degrees apart. Thx.
Edited by Ed (Ont) - 15 Sep 2021 at 7:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 8:49pm
I thought there was a TDC as well as FIRE mark. 30 deg stock. If high compression pistons you need to back off some. M&W's needed about 25 deg. That timing mark will likely move around some when running. Look for an average position. Maybe it's my distributor shaft LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 11:49pm
Yes Steve. TDC is marked as well. What would the compression ratio be if you had M&W pistons Steve?
Edited by Ed (Ont) - 16 Sep 2021 at 4:14pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 7:13pm
they were 7.25 ?....have heard 7.3. Have no information to support that. it's probably out there on inet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 2:40pm
Did you get those units timed Dana?
