Polarize C tractor
jpi72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Topic: Polarize C tractor
    Posted: 29 Aug 2021 at 12:31pm
How do I polarize an Allis Chalmers C generator?
Joel
jpi72@q.com
319-215-5420
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2021 at 12:44pm
If you have a voltage regulator, you touch the BATTERY terminal to the GEN terminal for 1 second to get a spark, prior to starting tractor.
if you have the original 6v NEGATIVE ground, you jump a wire from the NEG battery cable ( terminal) to the "A" terminal on the generator.. for 1 second to get a spark.
In summary it is always the HOT battery terminal to the "A" generator terminal.
Edited by steve(ill) - 29 Aug 2021 at 12:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 5:20pm
Mine must not be original.  It has a positive ground.
Thanks for any help.
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 8:26pm
Original 6 Volt systems ARE Positive (+) ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 8:52pm
my bad jpi.... I ment if you have POSITIVE GROUND, then you touch the NEGATIVE terminal ( hot) of the battery, to the "A" terminal on the Generator.. get a small spark... you do this before you start the tractor.
( your basically jumpering around the cutout).
Edited by steve(ill) - 05 Sep 2021 at 8:54pm
This page was generated in 0.274 seconds.
