Reversing a UC Sugar Cane |
Post Reply ![]() |
nowaktj ![]() Orange Level ![]() ![]() Joined: 13 Dec 2009 Location: Elk River, MN Points: 732 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Aug 2021 at 11:31am |
I have an UC Thompson Sugar cane that drives in reverse (all the forward gears make it drive opposite of normal). I want to convert it to a straight high crop which will allow the forward gears drive it in the normal manner
Has anybody taken an UC's rear axle apart so it gets its input from the other side of the pinion? Is it as simple as taking out the axles, separating the cast rear axle housing from the transmission, unbolting the carrier unit and reinstalling on the other side? Please let me know...thanks Terry Edited by nowaktj - 27 Aug 2021 at 11:31am |
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8572 |
Pretty sure you have it figured out. Been over 40yrs since I was in my UC so don't remember much.
allisrutledge ![]() Orange Level ![]() Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
Like Steve it's been a long time but you are correct just put the ring gear on the other side. Trying to remember but I think it was 1989 or 90. The original bearings are a little different and I hope yours are good. I had to get a doner UC for a final drive. Good luck
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87229 |
i put a "B" back together wrong once... Thats all i did to fix it.
Your bearing preload should be close, so you might have the right number of shims already... You might have to change one side to side to get the gear backlash right. Edited by steve(ill) - 27 Aug 2021 at 6:11pm |
Thanks guys for the advice. I did get it apart. Wow...these parts are heavy to deal with!
Post Reply ![]() |
