Locking Collars On Bearings ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Locking Collars On Bearings ?
    Posted: 20 Aug 2021 at 6:15pm
There's a a post on NAT about the "collars" on the bearing/shaft. A guy claims that the cylinder bearings on an L2 machine does not have the collar, only red LokTite to hold those bearings in place . Is he correct ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 6:43pm
Loctite red or green is a good idea. But, the truth is each side of the threshing cylinder has a nut on the end of each shaft. The nut squeezes a hub up against the side of each bearing keeping them from creeping on the shaft. Thus, no lock collar is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 7:07pm
Thanks for the clarification Doc Embarrassed
