Fiat Allis C10 dozer trans oil in engine
Simon12345 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon12345 Quote  Post ReplyReply Direct Link To This Post Topic: Fiat Allis C10 dozer trans oil in engine
    Posted: 19 Aug 2021 at 1:11pm
I have a C10 dozer and idk where the transmission fluid goes but it seems like the engine oil is going up.... How is that possible and have a do I fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 7:15pm
Simon, im no expert , but since no one has responded, i will.... On the larger tractors the transmission OIL PUMP runs off the torque converter / back end of the motor. I dont know about the smaller FIAT machine.. Do you have a trans oil pump that runs off the accessory drive ( motor) that could have blown an oil seal on the shaft ??
Thats the only way i see trans oil getting to the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon12345 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 9:47pm
I think it has something to do with a breather tube (it that's what it looks like) cuz it goes from the top of the front of the tranny there is a nipple and the other end goes on a nipple on the back of the torque converter. There's no clamps on it so I don't think has pressure, but I kept having trans oil leak out, but idk why cuz it wasn't overfilled. So. I put clamps on it and left the dipstick out, just in case it needs to breath. But the fluid still was disappearing so that's when I checked the engine oil cuz there was no where else it could have went, and that's when I noticed it was way full. And as for the trans pump, we just had one put on but I'm not sure what it drives of
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon12345 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 9:50pm
*off of. But the pressure seems fine (until it runs out of oil in like an hour and half of course)
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 11:46am
Try posting this on the Construction and other equipment Forum here.  Someone who doesn't check this Farm Equipment Forum might see it on that forum, and have an idea.  Your machine is a Fiat Allis 10C isn't it?
