D17 head gasket
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: D17 head gasket
    Posted: 02 Aug 2021 at 9:03pm
I bought a Agco head gasket kit for my tractor. Several folks on different sites discuss using a sealant on the gasket. Whats the proper way?? Thanks in advance, Ryan
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 9:33pm
brush on Aluminum paint
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 9:37pm
I spray on a couple coats of Permatex Copper Spray-A-Gasket. As per the instructions on can.
Edited by truckerfarmer - 02 Aug 2021 at 9:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 5:53am
Pretty much if you don't coat it with something (around pushrod holes and all water passages) it will surely seep oil or coolant somewhere.
Edited by DrAllis - 03 Aug 2021 at 5:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 12:32pm
What sealant would you suggest?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 2:20pm
I can't see what type of gasket you have, but anymore I use the blue colored Hylomar stuff, which is an anerobic gasket maker/sealer. Wipe it around everything thinly with your finger. Assemble and let dry overnight. Anything is better than dry.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 5:29pm
We always used and had good luck with Permatex Hi-Tack Spray-A-Gasket.
IDK what color the current version is, but “back then” it was RED.
We found that it was the best product to keep an Oliver 1600 Diesel head from leaking.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 5:47pm
I also use Permatex Copper 'spray-a-gasket'. Available at your local auto parts store, Permatex #80697
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 6:06pm
Permatex copper sray it shall be!! Thanks everyone. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 6:27pm
And, I always retorque COLD after a couple hrs of running time, which for me includes a dyno run.
Edited by DrAllis - 03 Aug 2021 at 6:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 10:30pm
I got the head off today and after cleaning up it looks ready for the new gasket. My question is how do you properly torque the two nuts on the thermostat housing?? No way I can get a socket on those two. Thanks in advance. Ryan
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 12:10am
At the dealership I worked at they had an OTC special c shaped wrench. It was a box end wrench on one end and a 1/2" square female socket on the other end so your torque wrench fit it. It was bent in a c shape so that your torque wrench was directly above the bolt head and you could torque it like normal.
Now at home I had a torque wrench that came with instructions that contained a formula to use so that you used a normal wrench and your torque wrench. You measured how long the wrench was center to center and, can't remember for sure but I must have had to double nut a bolt and put in one end of the wrench so I could use a socket and the torque wrench. Anyhow the setting on the torque wrench was much lower to take into account the length of the wrench you used. Google it and I'm sure you will find something.
Edited by Lonn - 08 Aug 2021 at 1:12am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 1:08am
Using a double box end wrench might work best but the formula is......... take the length of of the torque wrench (center of socket end to center of handle which is either marked or is where the handle picot pin is) plus the length of the extension wrench (center to center); divide the length of your torque wrench by that total and multiply by the desired torque. That figure will be what you set your torque wrench to. So........ your torque wrench measures 19" and your extension wrench is 8" and your desired torque is 90 ft/lbs. The setting of your torque wrench is 63 ft/lbs.
Torque wrench length = 19"
Extension wrench length = 8"
Desired torque spec = 90 ft/lbs
19 + 8 = 27
19/27 = .70
.70 x 90 = 63
Set wrench to 63 ft/lbs
Hope that helps
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 8:16pm
Awesome Lonn!!! Thanks and I will use your equation. Ryan
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 6:46am
https://www.allischalmers.com/forum/wd45-engine-rebuild_topic115588.html
Scroll down and see if you can find one of these wrenches. I bought one and used it on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 8:13pm
Awesome!! Thank you for sharing this valuable information Dave! Ryan
