5040 hard to turn
chefiam1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Topic: 5040 hard to turn
    Posted: 07 Jul 2021 at 4:41pm
chef  here! have a 5040 and it always been hard steering. well,
took off the steering cylinder and had it rebuilt. put it back on today and now it is even
harder to steer . any idea where to start? i'm not sure where to check the fluid.but
i followed the lines and all i could find is a dip stick on the right hand below the seat. checked it and it was milk color. if that is the right place to check it?all help is
welcomed!! don't have a manual yet. it belongs to my brother.
                                          Thanks,chef
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 8:28pm
An Owners manual would be your friend. I thought the Power steering oil tsank was under the hood near the top ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 9:47pm
It should have two pumps on side of engine. One in front and one behind front plate. One for hydraulics, the other for power steering with a small tank above engine.                  MACK
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 3:43am
In addition to what has been said check out the front spindles and keep them grease well
all the time.On basically the same Fiat built set up on my 2WD 1365 Oliver the bushing on the front spindle had locked to the shaft,swapped the front end out off a Long 550 solved the steering problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 3:44am
Some of the Fiat tractors used a separate supply tank,some pulled the fluid for the PS from the trans on the same line as the hydraulic pump.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:05am
Person that rebuilt it tell you about adjusting the P/S Cylinder control valve after you install on tractor and know you have oil pressure to cylinder . Have rebuilt  many of these over the years ,not just a reinstall   and go after rebuild.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 6:01am
After he got oil in reserve tank and got pressure ,and then understood   he have to adjusted cylinder  it's now  working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 4:42pm
chef here! things went very well with Fred  helping me out via phone.
thanks, for all the input and help got her adjusted thanks again.
                                             Chef
JLS retired View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLS retired Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 1:20pm
definatly check the front spindles!!! grease zerk is half way down the shaft and just because it takes grease doesn't mean both the top and bottom is getting grease. I don't remember the top but the bottom is just bushed and mine on one side was jammed from years of dust and mud. Had rebuilt the steering cyl. and I think I had to chase parts from Long dealer. Figured it out when I had a flat tire. Took pulling the axle on one side (porta-power) and a BIG press to push the spindle out, cleaned it up and it slid back in easily. Good times
