D17 Series IV 5 lug to 6 lug |
| Author | ||||||||||||||||||||||||||||
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Topic: D17 Series IV 5 lug to 6 lugPosted: 06 Jul 2021 at 8:04am |
The tractor is a D17 Series IV SN 78155. I was thinking of stepping up to a 6 lug. Do you know if I can use the same spindle and just swap the hubs and wheels?
Robert
1964 D15 Series II |
| Sponsored Links | ||||||||||||||||||||||||||||
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1768 |
Posted: 06 Jul 2021 at 8:36am |
The outer bearings are the same 5-bolt vs 6 bolt. The inner bearings for 5 bolt are 1.5" ID and 3" OD on the race. The 6 bolt inner bearings are 1.625" ID and 3" OD. You should be able to use the 5-bolt hub bearings in the 6 bolt hub. Never done it yet, but I will be swapping to 6-bolt hubs on a late D15 series 2 in a couple weeks.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Alvin M
Posted: 06 Jul 2021 at 8:42am |
I did one just changed the inner brg cup and race my brg suppler got me the parts
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5191 |
Posted: 06 Jul 2021 at 2:34pm |
Gee: you bent a wheel that stated was not for loader use when using a loader. Go figure.
ac45dave
Posted: 07 Jul 2021 at 2:06pm |
Robert I got my bearings for my D17 through Agco.They were surprisingly reasonable actually.Here are the numbers for DFW(narrow front) and RSFA(wide front).The inner bearing cone and cup are different from wide front to narrow front.The outer cone and cup are the same for both front end types.No spindle change needed to do this.
Edited by ac45dave - 07 Jul 2021 at 2:08pm |
