Looking for a 7020
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a 7020
    Posted: 05 Jul 2021 at 6:12pm
Do 7020’s if taken care of properly last over 6000 hours? Engine? Transmission? Or should I stick with a lower time unit? Personally I think lower hours as I am really a fussy guy. Opinions please. Thanks. Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 6:20pm
The most neglected system on those tractors is the cooling system. Failure to keep treated antifreeze or use of a coolant filter will in time lead to cavitation erosion of the wet sleeves. Now, and engine that works hard all the time (heavy tillage) will last a lesser amount of hrs as compared to an engine that only makes hay all the time. Cooling system also includes keeping the radiator core clean and fan belts tight. Those engines don't usually fair very well if run hot, as it can loosen the copper injector tubes in the cylinder head causing troubles there with coolant disappearing.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 7:54pm
Remember they are 40 year old tractors. 6000 hours would be only 150 hours a year. Find one with too low hours I’d doubt the authenticity of the hours. I’ve always been intrigued by a 7020 but sorta struggle to justify one. Ohh who am I kidding if I found the right deal I’d be tempted.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 10:41pm
never buy one that doesn't have a water filter on it!
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 11:04pm
There out there yet I found mine with 4,600 on it and put 300 hrs in the year I have owned it. Another thing is do not over look the trans filter. The previous owner was having trouble with reverse and then it wouldn't move at all. I found the trans filter plugged solid and changed fluids and now it will only slip in reverse under heavy load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 6:10am
Wow thanks y’all!
                          Dana
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 5:40pm
Well I was also thinking about up-grading from my 200 to a 7010/7020 to have a nicer cab but then a light bulb went off in my head. A really nice one would cost 10/12/15 thousand and then what if something castastropic happen like transmission, rear end or engine failure?  No dealers or mechanics around here will work on AC's even if you are lucky enough to find parts. Some guys can fix these kind of things themselves but what if you can't? So I decided to hang on to my old 200 till she croaks for good and look for a GREEN replacement. Dealers are plentiful and it might cost a small fortune to get it fixed but it can be done. Just pay the bill. Please don't get me wrong--I love the old AC's as much as anyone but they are a part of history now anyway you look at it and even the last ones made are getting very old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 6:24pm
KyAllis - nonsence !!!  Im only joking now , but do understand your thinking - my thoughts of the older AC tractors is to stay away from Powershifts as they are more complicated- Power Directors are alot tougher and parts can be made cheaper- in my opinion - one thing happening now is the Kubota older tractors with the slider trannys and easy shifting are becoming in line with older stuff price wise,, and usually parts are available if needed, with shops supporting those tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 7:51pm
What about Laker’s in Indiana or B&G in TN? I LIKE my Deere but not afraid of the true orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 7:56pm
I’ve had two PD’s over the years. Got irritated with 7080 and shipped it and if I find the right Deere I’ll ship the 7580.   We got three PS and prefer them hands down.   Might be reason most later model tractors industry wide were power shift till CVT and IVT came out.
Bought my 8050 with tranny issues closest salvage yard had a 8030 PS we cooned the guts from. BTW my 7080 had PD issues.
Edited by victoryallis - 06 Jul 2021 at 7:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 7:59pm
The last year of the 8000's built, Power shift units were over 80%.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 10:09pm
I have 3 8000 series power shifts. Had one since 93. Never an issue with any of them. The big one is an 8070 FWA and pulls hard. I’m not scared. If I find the right 8030 I will have the complete series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 12:06am
Never know when opportunity will present it's self my 7020 is the cheapest tractor I have both cost of operation and cost of purchase
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 7:09pm
Dang never wouldve thought the Powershifts were that popular , but Im still in the great One Hundred Series days , and only messed around with Powershifts some on ppls farms a little
Edited by DougG - 07 Jul 2021 at 7:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 7:32pm
Trying to run with Klee?
