Ford question |
HD6GTOM
Topic: Ford questionPosted: 30 Jun 2021 at 7:07pm |
Ok guys. I been working on trucks/cars since the 1960's. Son tried to help his neighbor out buy buying his 1994 F150. Short wheelbase, 5.0 motor 4 speed. You start it up. Not moving or moving. No dash lights/warning lights come on but there is a constant beeping sound comming from under the dash. Any ideas? Never heard or seen it before.
Edited by HD6GTOM - 30 Jun 2021 at 8:53pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 30 Jun 2021 at 7:19pm |
there is a separate fuse for the dash lights/ warning lights... might check that..... if the fuse is OK, the dash lights come on with the head light switch / dimmer switch..
ding , ding, ding when the door is open... Is that the beep ? Door switch might be STUCK or broken.. spray with WD40.
Edited by steve(ill) - 30 Jun 2021 at 7:22pm |
dee_veloper
Posted: 30 Jun 2021 at 7:22pm |
Likely an air bag sensor. Check for computer codes.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
steve(ill)
Posted: 30 Jun 2021 at 7:27pm |
do you have an Air Bag Light on the dash ( over by radio) ? If the BULB burns out, you will get an alarm that tells you to replace the BULB.
Edited by steve(ill) - 30 Jun 2021 at 7:28pm |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 30 Jun 2021 at 8:38pm |
1987's did not have air bags. The only thing stock that should beep is the headlights left on when the key is removed and the door opened or the key left in the ignition when the engine is off and the door opened. I would suspect the headlight switch but that should not affect the warning lights. That 5.0 and the 4spd (3spd w/overdrive) is a great combination.
HD6GTOM
Posted: 30 Jun 2021 at 8:55pm |
Guys my apologies. Its a 1994 5.0, 4speed with overdrive. The hydraulic clutch is low on fluid and I can't find my brake fluid.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25253 |
Posted: 01 Jul 2021 at 6:03am |
my vote's for the driver's door switch. my '97 did that ding-ding-thing, blew compressed air ,then some wd40, been fine ever since...til tomorrow, right ?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 01 Jul 2021 at 8:10pm |
I had a problem with one of my trucks with the door switch. My dome light stayed on all the time, which was pretty annoying at night.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 01 Jul 2021 at 10:21pm |
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 18 Jul 2021 at 2:28am |
Air Bag warning light is burned out. Pull the cluster and replace the bulb.
