D17 governor broke
chainweaver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chainweaver Quote  Post ReplyReply Direct Link To This Post Topic: D17 governor broke
    Posted: 25 Jun 2021 at 9:55pm
Friend's d17 governor gear broke in half & both weights are in the oil pan no doubt. Can he replace the assembly without dropping oil pan & fishing out the parts? Also the gear that runs it broke 1 tooth, does he have to replace it or can he get by? I'm sure it's been covered many times, I just can't find it. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2021 at 10:04pm
Have heard tell of gov weight going through drive gears and creating a burr on a tooth which led to bad harmonics causing more governor failures down the road. As Dirty Harry asks,"Do you feel lucky"?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2021 at 10:15pm
You can either fix it right or fix it again.  Your choice.
Drop the pan and make sure you get every piece of metal out of there.  Also replace the gear and everything else that got damaged.
Cutting corners in engines typically do not help long term reliability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 5:52am
Radiator and front support must be rolled away. Front pulley and timing cover and starter and oil pan must be removed. Now fix it. All THREE gears with new weights and pins. Be sure to check the governor assembly for gear backlash as the dowel pin may be missing. If people would replace governor weights every 1,000 hrs as a maintenance item, this would never happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 7:17am
Rough teeth  on gears will destroy weights. If gears are rough, replace  them.                MACK
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 3:13pm
This one area of the 226 engine where a little preventative maintenance can prevent very costly repairs. It is not that difficult to pull the governor and check the condition of the pins every now and then.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2021 at 7:16pm
I have a govenor and cam if needed
phil
This page was generated in 0.069 seconds.
