Preventative Maintenance for 8050 Ambac pump?
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: Preventative Maintenance for 8050 Ambac pump?
    Posted: 28 May 2021 at 3:23pm
In the process of buying my first tractor, '82 2wd 8050 powershift. Right at 5k hours and i believe its mostly original, its done some tillage and planting this spring and runs pretty good. It'll be used for 80 acres of row crops and i'm looking at making 30-40 acres of hay this year. The only other tractors in my family are a Deere 3020, Oliver 1650, and a TN75 loader so i see this tractor getting some hours put on it pretty quick. Last few years i've been around a 7020 and 7060 and they've been great/reliable tractors, i've been reading up on the 8000's and only real concern i have at the moment is the fuel system. I was able to run it a little and it seems smooth and responsive, but i've got 15 acres of hay to mow/round bale next week if the weather lets me so that'll be the first real test for me. Is there anything to pay attention to on the pump or injectors so i can avoid hurting the engine? Not looking to dump a bunch of money into pump work or an inline swap right away, but i don't want to miss something and cook the engine.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 5:49pm
Regular maintenance is just as important.
Has the rad been changed yet? rad hoses? thermostats?
As a forty year old tractor, they're probably past due.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 5:52pm
Run a quality Fuel additive like Alliant Power, or Stanadyne Performance Formula, and buy good filters. It will run a long time if taken care of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 8:42pm
Replace the fuel return line from pump back to tank. They get a lot of heat from exhaust manifold. After a lot of hours, they get hard and brittle causing them to break easy. Have sew some burn from return fuel spraying on hot exhaust manifold.             MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 9:34pm
I agree 100%!  I think the cooling system is the most important, yet most overlooked system on tractors.  Definitely get the radiator boiled out and pressure tested, hoses and thermostat replaced as well.  Check the water pump shaft for excessive play as well.
Fuel system would be next on my list - a good winter project.  Get the tank cleaned out, replace filters and get pump checked out.
