7000 and 8000 series hydraulic pump rebuild kit
Smallfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smallfarm Quote  Post ReplyReply Direct Link To This Post Topic: 7000 and 8000 series hydraulic pump rebuild kit
    Posted: 27 May 2021 at 10:28am
Wondering if anyone has found a good source for a seal kit to rebuild the gerotor and gear pump section of the 70271875 and 70268882 hydraulic pumps?
If not would there be any interest if I can source a manufacturer to build them?
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 12:11pm
Yes I need a kit for one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smallfarm Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 1:15pm
Ok, I dont have a timeline yet. Currently putting a used pump in our 7030 to get by, at the end of the day its still a 45 year old pump with 45 year old seals. At this point I am working with a machine shop and a 3D printing prototype company to come up with a solution.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 5:46pm
Eaton bought that pump design from cessna. Ive got one the only difference i can find is the case drain is a hole in the pump face back instead of external. I dont know if they still make them or the part number right now. Might be an avenue to keep an ohterwise good tractor out of the scrap yard. If there is any interest i can post the part #
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 6:07pm
Countryside Tractor in PA they rebuilt them they have larger gears and machine out housing 717-923-0421
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smallfarm Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 8:03pm
I'd take any and all information you have on an Eaton kit. My local Fleetpride hydraulic shop said he had exhausted all his options with Eaton. Told him part numbers were good but had been obsoleted years ago. He was thinking a 26 series kit would work but its a different size as the Allis is a 29013RAD pump.
Thanks for the information I'll be on the phone bright and early!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2021 at 12:53am
tagging for future reference
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.508 seconds.
