calcium antidote |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25533 |
Topic: calcium antidotePosted: 10 Sep 2010 at 10:37pm |
I have a tire that sprung a leak with calcium chloride peeing all over the wheel. Is there anything I can spray/toss/dump on there to neutralize the situation until I can get to taking the tire/tube/rim apart?
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2693 |
Posted: 10 Sep 2010 at 10:45pm |
I have one doing it also, when I park it on concrete I make sure the valve stem is on the top. Sometimes I have to jack it up and rotate. I'd just wash it with a hose, isn't it basically very concentrated salt water?
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 11 Sep 2010 at 7:43am |
Don't know of any "nuetralizing agent" (othe than lots of water and soap). Have noticed that the valve cores are the weak link with CaCl filled tires. I now change out the cores every other year (or more often if notice seepage). Rotate the tires so the stem is at the top, jack up the tire, bleed out the air, replace core and repressurize the tire.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42253 |
Posted: 11 Sep 2010 at 7:54am |
Lots of water, then more water. If it is leaking into rim (inside of tire) you need to get it drained and off soon. I used a small pump to suck it out along with air into tube , rotate valve to top, air tire with valve core removed, attach hose and rotate to bottom as hose discharges into drum. Lower jack to create more pressure on tire bottom to force more out.
Jack it up and do again
