8050 ps torque limiter
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: 8050 ps torque limiter
    Posted: 08 May 2021 at 11:03am
I have my 8050 split now and read the earlier post on the torque limiter.  What should I check as long as it is split?  My torque limiter all the springs in it were shot, so I ordered another one.  Should I replace everything?  It looked like the disc would have to be resurfaced, but the rest seemed alright.  I don't want to have to split it again for fun.  Thanks again in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 1:37pm
Not familar with this TL thing but like a clutch assembly id replace any wear item and id have the flywheel re done
4oranges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 1:58pm
I just did one (and posted about it here) a month or 2 ago. I had the flywheel resurfaced, replaced engine and transmission seals (mine were both leaking) replaced the bellview washer on the TL but I didn't replace the plate. Big mistake I think, it's bow slipping and I don't know what else would be causing that. I had the plate checked by a machine shop and they said it was true but there must have been something screwed up with it. The service manual says you can't have that resurfaced and they're only 160 or 80 bucks.
Long story short, as long as you're in there do all the parts you can get
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 9:06pm
4oranges is correct. Been down that road before replace all.              MACK
