Not AC
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Topic: Not AC
    Posted: 08 May 2021 at 7:07am
I saw the is FaceBook MarketPlace.   Not AC, but I read somewhere that LeRoi used an AC engine.   Anyhow, something different.  I did a little more research.  LeRoi bought Centaur, so I guess this could be called either.
Edited by Larry in NC - 08 May 2021 at 6:10pm
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 7:45am
     That would be an unusual project for someone. I never knew Leroi made a tractor. Did they make farm tractors too? The nose looks slightly reminiscent of an AC.
     Larry, thanks for posting.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 11:33am
20+ years ago I worked on a Leroi Compressor that had a Buda in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 5:08pm
Its a centaur tractor.  Look at the tag, if you don't believe me.  Probably a road mowing tractor, from the sickle bar bracket, hanging on the right hand side of it.  IIRR, these things had an incredibly fast road gear in them...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2021 at 5:58pm
Le Roi 105 TractairThe Le Roi company of Milwaukee, Wisconsin, manufactured engines for a variety of industrial applications. In 1940, Le Roi acquired the Centuar Tractor Corporation. Centuar manufactured a line of industrial tractors using Le Roi engines. Notable was the Le Roi Tractair line. These tractors used a six-cylinder engine in which four fired, and two cylinder were used as an air compressor. Le Roi was purchased by Westinghouse (WABCO) in 1954, tractor production ceased in the 1960s.
Tractair.com - history of the Centuar and Le Roi tractors
ModelPowerYears
Le Roi industrial tractors
105 Tractair35 hp1928 - 1950
125 Tractair42 hp1950 - 1965
Edited by Larry in NC - 08 May 2021 at 6:06pm
