82t sickle mower minimum tractor? |
Hunt4Allis
Topic: 82t sickle mower minimum tractor?Posted: 12 Apr 2021 at 5:23am |
When these sickle mowers were designed does anyone know what the minimum horsepower recommended to run them was? I've previously used my d17 to run it but I'd like to leave it alone and use it for a different task and utilize my CA to mow with and possibly rake with my Allis Chalmers b? It is the trailer type sickle mower... Thanks fellas!
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1084 |
Posted: 12 Apr 2021 at 5:51am |
I have used my 5020 and ca. Both work well
Edited by im4racin - 12 Apr 2021 at 5:51am |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 12 Apr 2021 at 6:00am |
I would think a CA should run one easily. I'd bet a B or C would too, but you might not have enough hydraulics to raise the bar. AaronSEIA
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3123 |
Posted: 12 Apr 2021 at 6:10am |
I've mowed a lot of acres with AC trailer type mowers pulled behind a CA.I like a smaller tractor to mow with can see better and less chance of tearing up something if some object like a rock is hit.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 12 Apr 2021 at 7:24am |
When I bought my first D-10, it came with a rear mounted mower. I, personally, have never used it, but I assume the former owner had.
Hunt4Allis
Posted: 12 Apr 2021 at 8:04am |
"Not enough hydraulic to lift bar"?( I'm assuming you mean a b or c would not have good enough power)? I just rebuilt my ca hydraulic pump last year... Edited by Hunt4Allis - 12 Apr 2021 at 8:06am |
Hunt4Allis
Posted: 12 Apr 2021 at 8:07am |
A model b run a rake for making round bales? ( Best rake for a "b"?
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 358 |
Posted: 12 Apr 2021 at 8:08am |
My 80T mower works fine behind my B.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54697 |
Posted: 12 Apr 2021 at 5:21pm |
It only takes a few HP to run a sicklebar. B, on up should run it!
AaronSEIA
Posted: 13 Apr 2021 at 5:58am |
[/QUOTE]
"Not enough hydraulic to lift bar"?( I'm assuming you mean a b or c would not have good enough power)? I just rebuilt my ca hydraulic pump last year... [/QUOTE] I would guess it has enough power, just not sure about oil capacity for filling a cylinder. You'd for sure want a small diameter one. AaronSEIA
Hunt4Allis
Posted: 13 Apr 2021 at 7:36am |
Ok, once I can make sure the front end isn't going to fall apart with the play in front cross arm hole I'll use her for mowing and my b for raking!
Edited by Hunt4Allis - 13 Apr 2021 at 7:36am |
