7000 Clutch brake
Williamsburg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Williamsburg Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Clutch brake
    Posted: 08 Apr 2021 at 1:49pm
I'm trying to adjust the transmission brake on my black belly 7000 (S/N 8572).
Service manual says set the brake spring to 2" +- at full clutch engagement.
My trans. brake spring is over 4" long and couldn't physically compress that much.
According to agco parts, there's an update kit.
Do I have to get the update kit to get my brake to work correctly or is there an adjustment procedure for the longer spring style???
Thank you!
Also, are there any good AGCO dealers that ship parts??
Edited by Williamsburg - 08 Apr 2021 at 1:52pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 2:04pm
Good heavens you don’t appear to be that far from Marshalltown. Central Iowa Farm store at one time was a big player call them.  Nothing else I know for a fact Williams’s in Charlotte mi ships I know one of the owners well.
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 2:12pm
Call albert at zeigler ag in Missouri Great to deal with and im in Central NY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 2:41pm
In the end, you want the big long updated spring to compress 1/4" when the clutch pedal is depressed all the way down to the stop bolt on the pedal. You can easily see this at the front of the spring on the rods sliding sleeve. So, if the spring isn't compressing 1/4" you move the front nuts forward enough until it does and then tighten the rear nuts the same amount as the front nuts to put the spring back to the proper length. You have the updated parts already.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:53pm
X2 on CIFS in Marshalltown
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 7:02am
Here is a link to the updated instructions:
If you would rather me e-mail the file, send me a PM with your e-mail and I'll get it to you.  I keep it in my onedrive to share so I can help my fellow black belly 7000 owners :)
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Williamsburg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 4:19pm
Yep, that's the one I have.
Thank you!
This page was generated in 0.191 seconds.
