Rear wheel eccentric???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel eccentric???
    Posted: 04 Apr 2021 at 9:22pm
Hello all.
Was going through a bin, has rear wheel body eccentric. But noticed all but one looked alike. And only one had part number on it. Is it possible that it might have same part number even if looks different or what other part number could I look into it being.
The one is 220756
Thanks for any help
Edited by Mikez - 06 Apr 2021 at 7:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 5:54am
WD-WD45 and D-17 are different than CA-D10-12-14-15.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 7:12am
Part number is the same and they interchange. I have swapped them on my tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 7:13am
the numerical book on that number showed all those tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 7:21am
I just looked at AGCOPARTS and see that the body is 220756 and the pin is 220600 and the block is 220032. Some of those tractors had a square head on the pin while others were hex head. I don't know how they can be the same p/n when they are different ??
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 7:52am
Dr.
I agree with the P/N's you listed. The Body 220756 fits WD, WD-45 CA, D-10, D-12, D-14, D-15. Not sure about D-17.
It is the pin that is different.
CA D-10, D-12 225189 with 1/2' square head
WD, D-14, D-15 220600 with 3/4" hex head.
G
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 9:45am
So......is the slot for the rail at the  opposite angle as well?...can't tell from the picture. Doesn't seem like that could be though. It looks like the eccentric would turn CCW instead of the usual CW on the oddball one on the right. Looks like a little less "meat" in the casting as well. Is it an optical illusion or is the hole spacing narrower on the one on the right?
I have 2 WDs, 3 WD-45s and 1 D-17 Ser. II and all of the clamps look like the one on the left.
Edited by Brian G. NY - 05 Apr 2021 at 9:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 7:32am
hi Brian, the slot is the same angle. And holes were same spacing. Sorry it was hard to get a good angle on picture.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 1:11pm
Mike
Did you look for a casting number on the different body ?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 2:15pm
yes casting number on the 220756 is AM 3600-5 and the different one is L84651    R
                                                             G  15
