D-15II |
Post Reply ![]() |
Darrell G (MN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2021 at 11:44am |
I recently acquired a D-15 series 2 and it's missing a carburetor, what carb does it usually have on it?
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8522 |
I would look for a Marvel/Shebler. Just like those better than Zenith. But that is just me. My guess is it could have either?
Regards, Chris
Walter(MO) ![]() Bronze Level ![]() ![]() Joined: 26 Dec 2009 Location: Warrenton, MO Points: 127 |
My D15 has a Marvel Schebler carburetor on the tractor. I am sure this was from the factory because the tractor only has 1800 hours and the meter does work.
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
Marvel Schebler carb# is TSX869 For S2
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
No Zenith ever on a D-15 S-2
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87869 |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
ours has the TSX-869 on it
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
https://www.carburetion.com/Products/SearchAll.aspx?Search=tsx844 Edited by steve(ill) - 31 Mar 2021 at 12:21pm |
G-149 in early D-15's have a much smaller carb than the G-160 in the series 2.
den/southern illinoi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2068 |
The service manual I have says they started with MS TSX 815. After serial #3359 they went with a MS TSX844. Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5900 |
My Series II has a TSX-844 |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10791 |
Both of mine have 869's on them. Tracy
modirt ![]() Orange Level Access ![]() ![]() Joined: 18 Jul 2018 Location: Missouri Points: 8736 |
Carb as found on D15 II I'm currently stewarding...... ![]() |
A Marvel carb from a series 4 D-17 can be made work by changing the throttle shaft or welding a new lever to the D-17 shaft.
Post Reply ![]() |
