Rear tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Rear tires
    Posted: 14 Mar 2021 at 12:01am
Hello
It’s looking like we’re going to have to replace tires on rear of 6080. What do you all prefer, radials or bias-ply. It’s a 2wd with cab and has bias on it now. What’s the pros an cons.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 7:05am
Radials are were generally designed to increase traction to get more pulling power. They usually ride better. They will cost MORE. Probably last longer. May not be a good choice when used without duals on steep sidehills. Not sure how the tractor is going to be used, so that makes a difference too.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 6:52pm
I put bias plus on mine they were a lot Cheeper but my tractors mostly sit around taking up space in the tractor shed. The tractors at the farm all have radials they work for a living. Radials have better traction better flotation and ride better. My 190 has very worn Michelin radials it's amazing how well they work with almost no tread. The 1086 I mow ditches with has very worn loaded radials. The flotation and traction is better than the yard tractor another 1086 with fairly new looking bias plies
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 8:57pm
This article compares them. It shows how their designs differ. Hope it helps.
https://www.ntstiresupply.com/ptk-shared/bias-vs-radial-tractor-tires-what-is-the-difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 10:10pm
thanks. It’s mostly hay tractor. Far amount of road travel. Vary little tillage. Some hills
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 6:35am
curious am I...
re: May not be a good choice when used without duals on steep sidehills.
Why ? If they have better traction, won't they 'grip the hill' better ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 6:53am
think because side walls give.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 7:26am
Some brands are worse than others for the hillside wandering. Duals firm things up a lot.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 7:39am
Only bias tires here.  Lots of hills where I am with some that are steep.  Had an AGCO  that came with radials and tore up a hill hauling hay out.     Changed over to bias when the radials wore out and it pulls on the hill so much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 8:29am
re: side walls give.
so the tractor 'wobbles' left to right  going up or down the hills ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 8:41am
they only squirm if you go to the real tall skinny tires. we have 14.9x 42s on most of the 2wd tractors. without duals they squirm but the tires are really to small to be running without duals the bare tractor is over the load limit for that size tire when singled. 18.4x38s are fine singled.
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 8:54am
Have you found any 18.4x28?   Or does your 6080 have 30's on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 8:58am
I'd expect a 6080 to have 18.4 x 34's on it.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 9:50am
Jay it is when you would be driving parallel to the hill or sideways to the hill. The sidewall would give.
Edited by farmboy520 - 15 Mar 2021 at 9:51am
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 11:44am
16.9x38 on a 6080 are cats meow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 1:04pm
My 190 has Michelin X radials 18.4x34 I have no problems on any side hills. I have 10 psi in them and don't get any side slippage and they flatten and give a nice footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 1:45pm
thanks sounds good. There  18.4-34
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 11:28pm
Mike if you are using this as a main tractor, plowing etc I'd consider radials. If its a chore tractor, haying, light field work I'd go with Bias ply. After selling many different brands of tractor tires during the 20+ years I owned the farm tire dealership, I'd have to recommend the better Firestone's. In sold BKT for chore tractor tires those tractors seldom left the farm lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 11:42pm
Mike. Here are a few tire prices. If I still owned the tire shop Mitas 8 ply bias would cost $652.47 each installed on the tractor at the shop. No fluid pumping included in this price.
Mitas Radial 46085x34 $863.01 each installed, no fluid.
Trelleborg TM 600 46085x34 A8's $1060.34 each no fluid.
My tablet acquired a virus a couple of days ago and I can't yet get on the Firestone/other tire brand wholesalers website. Use these for comparison. If you use tubes, Please get heavy duty tubes for them. The standard duty tubes turned to crap about 15 years ago. Tube prices are not included in the above prices.   After several very bad experiences with Titan and Continental tires I would not recommend them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 11:53pm
really what happened with titan tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2021 at 12:13pm
When they went from Armstrong to Titan they cheapened up the casings. It became very thin. Corn stubble went right thru them. The first year we sold farm rears I sold a lot of Titan rears. I actually took some of them off and put Firestones on.
This page was generated in 0.135 seconds.
