Power Shift Transmission 8070 |
johnny s brooks
Topic: Power Shift Transmission 8070Posted: 11 Mar 2021 at 3:52pm |
Does anyone know if the power shift valve body assembly from an 8070 will bolt up to the transmission housing of a 7045? The reason I would like to change the valve body is that the 8000 series tractors have an oil seal where the lever assembly comes out while the 7000 series tractors have an internal o-ring that is prone to wear and leak (like a major leak).
DrAllis
Posted: 11 Mar 2021 at 7:16pm |
Bolts right on.
MACK
Posted: 11 Mar 2021 at 8:18pm |
One reason the old style leaks is because oring gets cut on assembly . If you go to new style , peen around seal to keep it from coming out. MACK
johnny s brooks
Posted: 12 Mar 2021 at 6:38am |
Thanks. I'll check on prices at the salvage yards. If I can stand the cost, I'll make the change.
DrAllis
Posted: 12 Mar 2021 at 7:14am |
I used to add a second oring groove to the old shift shafts.
johnny s brooks
Posted: 14 Mar 2021 at 2:39pm |
Thanks, Dr Allis. Was this a permanent fix or a stop-gap measure?
DrAllis
Posted: 14 Mar 2021 at 6:00pm |
Pretty permanent. Better than one for sure. Even an 8000 needed a seal once in a while.
MACK
Posted: 14 Mar 2021 at 8:53pm |
To keep from cutting oring, slide shaft all the way through , install oring with grease, then pull back into place. MACK
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 14 Mar 2021 at 9:04pm |
the cab mount holes on the ps housing are different - the tool is different on the two series - have to address that issue.. we just did one.
johnny s brooks
Posted: 16 Mar 2021 at 6:25am |
Thanks to everyone. Appreciate the expertise and help.
johnny s brooks
Posted: 16 Mar 2021 at 6:26am |
