Drilling rotary cutter blades
AC since 12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC since 12 Quote  Post ReplyReply Direct Link To This Post Topic: Drilling rotary cutter blades
    Posted: 08 Mar 2021 at 9:57am
I have a 48" Club Clipper belly mower on my B. I could not find blades for it. I fownd some Woods blades on RCS that will work. The only problem is they need new holes drilled in them. They are really hard. I have tried high speed drill bits, cobalt bits. Nothing works. I have thought about heating them before drilling, but I am not sure what this would do to the temper of the blad.It would also ruin the bit. Any suggestions.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 10:54am
Not sure what size you need to go drill?  And what do you have for a "machine"?  But carbide should drill it.  Pricey, and in a hand drill you'll probably just chip it, but it should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 10:56am
Heat might be OK too.  If you soften the center area of the blade, the cutting are will still hold an edge.  Might wollow out the holes though, just all depends on many things..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC since 12 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 1:51pm
7/16 is the six I need to drill. I am using a Drill Press at a low speed.
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 1:57pm
Long shot suggestion but a machine/tool and die shop with a punch press to punch the correct size hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 2:46pm
On a drill press, IF you want to try a carbide drill, be certain your vice is secure and other items don't have slop in them.  It won't be forgiving to anything "grabby", or it will chip.  A mill would be better, if you had a buddy with a Bridgeport or something.
Edited by Tbone95 - 08 Mar 2021 at 2:47pm
JTOOL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 5:23pm
I was told several years ago that if you heat it red hot and let it cool slowly, then that softens the metal. I've never tried it. I don't know if slowly means let cool back to ambient or put in warm sand or ash. Then after drilling your holes, heat it back up and then quench it in something. Again, I don't know if that means water or oil or super quench. Let us know what you end up doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 8:42pm
At work the Machinist use to take carbide concrete drill bits and resharpen them with a cutting edge for steel.. Worked on Most hard steels... They used them to driil out broken bolts / old drill bits/ etc.
If you have a plasma cutter, you could blow the hole thru, then grind it to size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 9:02pm
I agree with concrete bits. May need ear plugs, it will squeal like a pig caught in a fence .                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 10:16pm
I would take it to a machine shop and have them do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 10:20pm
Let a machine shop do them in a vertical mill and use carbide cutter. Much better , cheaper and damn sure safer! HTH Tracy
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 11:18pm
Tracy,
Safety is something I thought of AFTER I posted. Probably don't want to go messing with the temper of steel. Especially at the speeds that mower blades turn.
steve(ill) and MACK; What is used to sharpen/reshape the blades? Grinder? Flapper wheel? Thanks.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 11:19pm
Whoops!
Not blades; concrete drill bits. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 4:45am
Originally posted by JTOOL JTOOL wrote:
Whoops!
Green wheel...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 6:52am
Concrete bit is an interesting idea.  Carbide tip to cut the hard metal, but steel body so not so likely to break.  Carbide is a bugger to grind though, diamond does it the best.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 7:10am
Water jet would work really well...if you can find a shop that has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC since 12 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 7:04pm
Thanks everyone. Now you have me thinking. I'll let you knoiw how this turns out.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 7:21am
LOL
1968 D15D,1962 D19D
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 4:56pm
There is a company called Rodman, and they make carbide drill bits, looks a lot like a hammer drill bit, but are used for drilling tough things like stainless steel.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 5:57pm
Mark where you want to drill the holes. Heat a spot the size of a dime red hot. Let it cool slowly and then drill. It will drill easily. Did this several times on dump truck boxes. Lot of these boxes are made from “hardox t100” steel. Drill bits won’t do anything but squeal. After heating drilled easily. Of course that spot is now weaker so make your decision accordingly.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 6:20pm
I have done as Ed stated. Only heat a small area. A cutting torch tip works best for this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2021 at 6:59am
There's probably 300 companies that make carbide drill bits!WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2021 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2021 at 9:31pm
YEA Allen............ that would work !! Wink
"drill bit must be run a minimum of 2000 rpm"... WOW.. never would have guessed that.
Edited by steve(ill) - 11 Mar 2021 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2021 at 4:37am
Like these?
That reminds me of the guy demo-ing them drill bits, at the farm shows, NC accent, and a total intact finger count of 6, on both hands!Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC since 12 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 2:17pm
Well they are done. I decided to Take them to a local machine shop. As it turned out I knew the guy who worked there. He used a water pressure machine to blast the holes through. It took about 10 minutes . The holes are perfect, and the blades fit well. I also  got to see their setup. The said if I need anything else let them know. It turned out to be a good experience.Smile Thanks for all the suggestions from everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 6:41pm
 RED HOT is a very loose term. Really red hot will cook the carbon out so you won't get it hard again. Critical temperature is where it needs to be to harden, and that varies with the type of steel. Quenching can be done with air, water or oil, depending on the type of steel.
 Annealing temperature is lower than the critical temperature, maybe just starting to show a red glow, and cooling should be SLOW.
 After re-hardening, it should be put thru a draw heat, which kinda stress relieves the part and lowers the hardness a bit so it doesn't break like glass.Ouch
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 6:47pm
YEP... When FIAT and ALLIS got together, then wanted to send over TRACK CHAINS for the larger tractors.. We told them ours were TOUGH and would last forever.. They said their were HARDER !!.... ALLIS chains were like a hammer head.. TOUGH all the way thru.. FIAT chains were " red hot and quench".. Top 1/4 inch was hard as a FILE... after that it was PURE MUSH.. Wear thru the surface and they were GONE !.  ... You got to know what your doing when you HARDEN STEEL.
This page was generated in 0.395 seconds.
