185 upgrade valve cover bolts |
Post Reply ![]() |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3025 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Mar 2021 at 7:24am |
Hello Guys,
I've been busy and haven't been on for a long time, but everything is good. I'm finally giving my 185 Diesel some overdue TLC. The pump is off and sitting at Ed's shop for a rebuild. The valve cover has been leaking pretty badly so I'm fixing that too. A few years ago, someone was talking about upgrading the 180-185-190 valve cover bolts to a style off the newer tractors that had an internal spring to hold the right tension. I forgot now but I'm guessing it was of A 7000. I looked up the 7000 parts book and I think bolt 74036972and washer/spring 74036973 is what I need. Can anyone confirm this is correct and is this actually worth switching too? I'm sure there's a different torque spec or something I should be using when installing the new style.
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2356 |
Get a 74036977 kit and follow the instructions that are included.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Yes, the bolts and spring washers will work, but regular bolts will also if proper glue and properly torqued . 1/4x3/4. MACK
Thanks guys. Kit ordered form Sandy Lake $60
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 797 |
Kit from Agco is 52.38
Post Reply ![]() |
