will a loader from a d17 fit a d15?
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: will a loader from a d17 fit a d15?
    Posted: 05 Mar 2021 at 5:23am
i can buy a loader with pump and all for 700.00 its on a d17 now can that go on my d15?.. i can get a pic later think its a 400 loader?
Strokendiesel002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 7:40am
I don't remember if the 15 and 17 frames are similar enough in width, but for $700 if it doesn't fit I can't imagine you'd lose money on it. I paid that for mine (which didn't have the pump, valves and all required plumbing) all said now, I'm about $2K into adding that loader. While I'm not regretting spending that amount, I sure would have been happier at half :)
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 8:01am
I have a 415 on my D17 series 3 fits fine except the back angle irons that go to the axel are different angles it should fit fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 9:00am
Sorry no pump on front goes into hydro on back
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 9:27am
A 400 loader is an all hydraulic loader. It requires FOUR outlets on the back of the tractor. The frame width of the tractors are the same. The D-15 is a little shorter and the axle connections are different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 10:17am
re: but for $700 if it doesn't fit I can't imagine you'd lose money on it.
I took 2 complete units from D-14s to scrap yard 2-3 years ago...ZERO interest in them, 1 had new,rebuilt cylinders...now IF they'd been 'green'..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 11:11am
Mike,
Do you know if this is currently on a Series 4 D17? If yes, then the remotes(valves) are probably not included with the loader as the series 4 had live hydraulics and often came with remotes (I believe).
If you don't have live already on your tractor you'll really want to add it, as 1.5gpm from the factory pump will be unbearably slow.
I use the tank built into the vertical post for my hydraulic tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 11:12am
I missed out :(
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 11:30am
He says it has the pump so the remotes are not an issue. You only need the shaft for a D15.\ and the rear axle brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 4:48pm
Joe is right all that is different is the front shaft and the back angle iron as I said before . You can get new pump parts from Aand W in Green Bay
