Opinion on CA/B hybrid tractors
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Opinion on CA/B hybrid tractors
    Posted: 16 Feb 2021 at 9:11am
I regularly see the front half of a Model B added to a Model CA rear to get a wfe on the CA or swap a CA rear to a B to get better gearing and a road gear. The result ends up with the front and rear wheels not tracking in the same ruts and frequent jury rigged steering linkage.
The B steering box is rarely swapped at the same time to improve steering geometry, as many of these hybrids use cobbled drag links off the CA pitman arm (points up).
Are these tractors abominations or more interesting to a collector?
Here is a better example of a custom drag link off the CA pitman arm:
Edited by KMAG - 16 Feb 2021 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 9:20am
i think its just a work tractor............ i dont see why anyone would COLLECT one.
Now a 4 speed transmission from a CA would be nice in a B..new hydraulics. Not sure about the final drives... too wide.
Edited by steve(ill) - 16 Feb 2021 at 9:22am
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 10:20am
How do you put B final drives on a CA trans?
I dimly recall they don't bolt on. Some minor machining or casting trimming was needed. Anyone here manage it?
I can see the advantages of a CA trans in place of a B's 3-speed. I would still have a lighter tractor and be able to do tractor parades (10 mph min), assuming CA's extra top speed wasn't from it's taller tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 11:59am
Final drives include the rear axle tube, unlike a WD series where the tube was separate to the final drive housing. CA road gear is faster than a "B", yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 12:45pm
Dr... the road gear of a CA is faster than a B.... Is that all in the transmission gear ratio, or is the final drive ratio of a CA drastically different than a B ?
My question is putting a CA 4 speed into a B and keeping the B narrow finals .
Edited by steve(ill) - 16 Feb 2021 at 12:46pm
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 1:29pm
have an IB with a ca 4 speed B finals and D15 gov spring [ 2000 rpm ] runs about 17 mph
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2022 at 9:37am
looks like the one in the picture , it dosnt steer backwards . the ball and socket end on the axle is all tie wired on and needs to be fixed before it leaves our shop here because the engine stuck over the winter
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:26am
how do you slow a B down?
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:57am
Not sure why anyone would want to put a B wide front on a CA since the CA came in wide front and narrow front, I have one of each.
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 11:13am
there are 5 flavors of gears that fit into those finals   B have 67 teeth  c has 94 or 82 or 69 depending on steel or air tires and serial number  while CA has 77 teeth
not sure what it takes to swap back and forth , pinion shaft length would come into play
i have both a B and a C (82T) .. the B is noticeable faster in 3rd   in 2nd its a wash
