8550 ELECTRIC FUEL PUMP? |
Gavin3
Joined: 23 Jan 2013 Location: Wood River Points: 12 |
Topic: 8550 ELECTRIC FUEL PUMP?Posted: 01 Feb 2021 at 10:13pm |
Was just wondering if the electric fuel pump on a 8550 or 4w-305 was an factory option or if that was something people added onto the machine. I am wanting to installed one onto my 8550 and I was wanting to install it were it would be if it was installed at the factory. But I have no idea where it would be mounted. if they were not a factory option I will probably installed an after market one onto the machine. Just wanted to pick your guys brains on this one for a bit. Thanks
PeteMN
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 209 |
Posted: 02 Feb 2021 at 6:46pm |
Agco parts books don't show an electric lift pump for it. Our 8010 has one, but the 8050 does not. I had to replace the one on the 8010, but didn't want to spend as much as Agco wanted so I just bought an aftermarket one like Carter makes. Doesn't need to be very much pressure. So far it's been working fine. It's mounted inside the frame rail so it doesn't get bumped by anything.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Posted: 02 Feb 2021 at 8:13pm |
ive used 2 different transfer pumps both work well on my 7080 one was a holley pump we bought from a race car supply store and the other is a eldrabrock i bought from oreliys auto parts store they make them for gas and diesel they mount inside the right frame well it was around 85.00
Gavin3
Posted: 02 Feb 2021 at 11:06pm |
Ya thats what I was thinking I was gunna do. Thanks for the info fellas.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 07 Feb 2021 at 4:25pm |
I believe the factory "kit" was a Holley Red. Primarily for 7000 series with the 426 engine with the Roosa pump. Not sure they offered it for the big girls.
The cheapies at the auto parts store cant even keep up with demand on a lowly old 6.5L GM diesel pickup, so i'd avoid them, If you can swing it, I'd consider a Fass or airdog system. A little more budget friendly but good flow is a Raptor pump. |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 08 Feb 2021 at 6:45am |
I bought a good quality electric pump from inj pump Ed (on the forum here) for my 8550. Mounted it down by the base of the fuel tank, so it is gravity fed an ample supply of fuel, then ran a line up to the filter housing. It is adjustable pressure, and I have a fuel pressure gauge on it. Turn it on and off with a toggle switch. I really should wire it onto a relay and run it off the key switch. Works good. Darrel
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 08 Feb 2021 at 7:44am |
we have a holly red pump on our 7580
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Alvin M
Posted: 08 Feb 2021 at 9:01am |
You can use Carter # P4594 or NAPA FE0539 6 to 8 lbs PSI
Dave974
Joined: 18 Aug 2017 Location: Fort Wayne, IN Points: 77 |
Posted: 08 Feb 2021 at 9:35am |
This is the pump I've been using on my 7080 and seems to work well.
Jack(Ky)
Posted: 08 Feb 2021 at 6:56pm |
My late 7020 has the factory electric pump and it had a "red Holley pump" I got a new one identical to it from Summit Racing for about a $100 bucks.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
