Oil change 170 gas
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: Oil change 170 gas
    Posted: 31 Jan 2021 at 8:31pm
What modern oil should I use for an oil change? It has 4200 hours, I was thinking 15/40 the same as we use in our other diesel tractors. What say you?
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 9:53pm
That will work. Keep it simple. If it is a wintertime tractor, I'd be using 10W-30 or 5W-30 unless in heated shed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 10:20pm
I use 10W30 Walmart full synthetic in the WD & 45 year round.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 12:03pm
Guys, I posted about this a couple years back as did Don(Mo) and we both got grief over it.Your synthetics and modern day gas engine oils are mostly low zinc and sulfer oils now days do to the epa.In these old flat tappet tratcors you need higher zinc than what these oils provide.Don was seeing a lot of cam failures in many of the engines he was overhauling do to this change in oils. Your best bet is a diesel grade that will have this. The two most common are rotella 10w-30/15w-40 or motorcraft 10w-30/15w-40(10w-30 for winter for sure).Valvoline VR1 is another choice but pricey. Rotella straight 30 wt is a low zinc oil now as are Delo and Delvac which are not what you want for flat tappet engines..This info is available on the Pqia site and the manufactures web sit in thier PDSs(product data sheet). I personaly use the motorcraft superduty 10w-30 diesel grade in all my gas tractors.It has a bit more zinc than the rotella.  It,s your cam shaft, do as you see fit.  http://pqia.org/heavy-duty-diesel-engine-oil/
Edited by ac45dave - 01 Feb 2021 at 2:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 12:09pm
This low zinc issue affects EVERY Allis-Chalmers engine, gas or deezel. Also affects a Deere 4020 or IH 856. All are flat tappet camshafts.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 6:47pm
Is there a good oil additive to add to the oil to boost zinc levels in most any oil one chooses to use, or an oil that has a good level of zinc still in it?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 7:36pm
You say it's a gas tractor so I would recommend 10w30.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:13pm
Yes, there are many oil additives to raise your zinc levels. I've used ZDDP brand and felt it was a good product. Any good Auto Parts store should have something on the shelf.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:16pm
Thanks, Dr.!  I'm going to check that out.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:33pm
I use valvoline VR1 in my 170....it has a lot of sink in it for the older motors with regular (flat tappet) lifters
It might be a little expensive... But its better than putting a cam and lifters in it
My .02
Ocharry
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:07pm
Thanks guys for the info. Our newest engine is a 1992 JD and goes down from there and are all Allis. We get our oil from JD by the drum 15/40 plus II 50 I guess I should check to see the specs. thanks again
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:12pm
Zinc levels have slowly been reduced over the years to help diesel engines meet emissions specs. Most modern engines have roller lifters/camshafts, which don't require the high zinc levels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 11:15am
Marv, I'm looking into this as well. I got calls into a couple deer dealers regarding their torque-gard line of oils for zinc numbers.This line of oil MAY be a good option. They're summitting a dtac case for me to hopefully get this information.We'll see what comes. The  15/40 Plus 50II your using may be short on the zinc do to it carrying the Sn API service rating for gas engines, which is geared around protecting catyletic converters.Most diesel oils having both ck4 and sn ratings are low zinc/phos oils.If they have ck4 rating only they usually have the higher numbers we're looking for. PM sent also.
