Wd45 wheel locks |
D14JIM14
Bronze Level Access
Joined: 25 Jan 2020 Location: Brazil, indiana Points: 190 |
Topic: Wd45 wheel locksPosted: 21 Jan 2021 at 10:50am |
I have heated , hammered impact wrenched and long bar , but I can't get these locks turned to loosen the wheel rails !!
This tractor sat 30 years and this tire went flat and spilled calcium all over the rim sometime during those years . The rim is salvageable but I can't get the wheel out to clean the rim up well . I'm about ready to cut the wheel locks out and get new used ones . Any suggestions ?? |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 21 Jan 2021 at 11:22am |
Did you heat the right end? The thread is near the head and the rest of the bolt is just a smooth rod/pin.
john(MI)
Posted: 21 Jan 2021 at 11:27am |
Take the tire off the tractor and lay it on the ground. Remove the eight bolts holding the eccentric on the center. With a large hammer and a piece of wood smack the center until the center and eccentrics fall out. Be sure to gather up the four eccentric pieces that go between the eccentric and the rail. Put the eccentrics in a vise. Using a torch, 1/2" impact and a hammer and drift, just keep working at it until they come loose. There are keeper spring washers on the back of the eccentric bolt that you need to remove before beginning working on the. I have also heard of putting them into a wood stove to get them loose. I've never done this so I cannot comment on it.
D14JIM14
Bronze Level Access
Posted: 21 Jan 2021 at 11:36am |
Thanks Dusty and John .
Heated the correct end .. I've had them be stubborn before but not like this ! John, I'll get a 2x4 and a BFH and see what happens . Thanks again ! Jim |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 21 Jan 2021 at 1:01pm |
Have you tried unbolting the clamps from the center?
D14JIM14
Bronze Level Access
Posted: 21 Jan 2021 at 1:09pm |
Yep but wheel is tight ! Loke CV I said a big hammer . Will let you all know how it goes when i get home and work on it again .
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5161 |
Posted: 21 Jan 2021 at 2:58pm |
As always with calcium in the tires: It's not if they will leak, but WHEN
. Also how much damage will it do when it does. Once you get things apart, and the tire dismounted, heat the rail directly where the stop bolt is and then you should be able to remove the stop bolt.
D14JIM14
Bronze Level Access
Posted: 21 Jan 2021 at 3:27pm |
Beat the wheel out and eccentrics are soaking in pb blaster . Will put in a vice tomorrow afternoon and start trying to turn !
Huolti
Joined: 03 Sep 2017 Location: Alberta Canada Points: 38 |
Posted: 21 Jan 2021 at 9:18pm |
Had same problem with eccentrics.Got them off the rim and hub and then used heat and a small hydraulic press. Finally broke loose.
fleeter allis fan
Joined: 05 Apr 2018 Location: Niagara Ont Points: 135 |
Posted: 21 Jan 2021 at 10:00pm |
It is important to remember that when you heat two components that are rusted and frozen together, you are attempting to expand one component in relation to the other. If you heat the entire assembly, both components expand at a similar rate (assuming both components are made of the same material) and you often don't get far. I have had some success using water or even ice to try and keep one component cool while heating the other. That way, the coefficient of expansion of the two components is different and you can hopefully break them free.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620 |
D14JIM14
Bronze Level Access
Posted: 23 Jan 2021 at 8:58am |
Got the eccentrics apart !!
This tractor has 2 stop blocks on one rail . One I heated and got out, the other the head rounded off with a 6 point impact socket ! Gotta work some more on that one ! |
john(MI)
Posted: 23 Jan 2021 at 11:22am |
Be careful with heat on a rim. The tire will explode from very little heat. There was a video someone posted on here. It was pretty scary!
Northern Hoser
Posted: 25 Jan 2021 at 11:48am |
Just did this on a WD, definitely unbolt the clamps from the center piece and hammer the rim and clamps off. Then go at freeing up the clamps with heat. Wasn't too bad, lots of heat and hammering.
