hand start tractor drill adaptor
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: hand start tractor drill adaptor
    Posted: 20 Jan 2021 at 11:42am
Has  anybody  tried to adapt a way to use an electric drill or  battery drill   to start a hand start B???????    have an  idea it  might  work  any  suggestions  ?    or  thoughts
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 12:02pm
You would need a very good drill I would think. Mine is just a standard 3/8" chuck so nothing huge but I had tried once with a socket adapter to start a tecumseh 12hp with it that had a bad starter and it didn't spin that well enough to start it trying to get over compression. If you had a big industrial drill maybe but it would need a good amount of torque.
Edited by cpg - 20 Jan 2021 at 12:02pm
Tbone95 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 12:08pm
I can't imagine a drill having the combination of torque and then the acceleration a man puts on a crank. I've never tried or even seen anyone start a B, but I have seen my dad start other tractors.
Edited by Tbone95 - 20 Jan 2021 at 12:09pm
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 12:22pm
Even with a heavy 1/2" drill motor, which is already geared down, you would need more speed reduction gearing to get the torque needed to turn the B over, and then, if that by some engineering quark, should work, I doubt you would have the speed......although I have been wrong before
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 12:57pm
I'd like to know WHO in their right mind would actually hold onto an electric drill to start a B !!!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 1:12pm
better have a strong wrist IMO
Wink
I am a Russian Bot
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 2:43pm
And to think its 2 months left to Winter
nonetheless ,still dead.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 2:57pm
I used  a 3/4" shaft with a pin in one end and turned down the other to 1/2" chucked in a Milwaukee heavy duty drill.  Cranked motor pretty good, had a handle out each side, eventually stripped a gear in drill.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 4:30pm
I have a VERY large drill equipped with a Morse taper that I once used to "try" to start a 4 cyl Continental engine on a DC Welder for a friend of mine. ' never did get it started that day but we must have turned it over on and off for a half hour. We welded a piece of rod to a sawed off drill bit and put in a cross pin to match the hand crank. Believe me, we did not attempt to hold on to the drill: instead, we blocked it up really good with cribbing.
It had way more torque than required for that little engine. My drill is geared way down but I think it still turned the engine over faster than a hand crank.
So....if you have a big enough drill, it is certainly possible. You just have to be a little innovative in building an adaptor which is not that difficult.
Edited by Brian G. NY - 20 Jan 2021 at 4:34pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 8:55pm
I saw this set up at a show several years ago.  The guy had increased the compression on the B making it harder to crank start, so he came up with this.  Once he had the Briggs fired up, it wasn't long before the B was running.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 10:00pm
If you could find one of them starters they use on the formula one cars it would probably do the trick.  Another thought that might be cheaper would be a hydraulic motor.  I wonder if you could run a belt from a belt pulley on one tractor to the belt pulley on the B?  A friend used to start his smaller tractor with the neighbors H that way.
A few ideas!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 10:30pm
At one time you could get a gear reduction to add to starters.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 6:45am
It'd 'B' a LOT easier and cheaper to just add the OEM starter......Big smile
You could lengthen the hand crank. That'd give you some advantage....
I'm wondering how many HP you need to spin the engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 6:53am
To me, the thing you need to do if you don't want to crank start it anymore is change the torque tube over to a Starter motor setup, and stick a Starter motor in it. Why kill yourself with somethin' like that? That to me is setting yourself up to get hurt! Tough to get things done when your hand or wrist is in a cast......  just sayin'....  LOL!
Steve@B&B
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 7:47am
...  I wonder if you could run a belt from a belt pulley on one tractor to the belt pulley on the B?  ...
I've done that a few times when nothing else worked.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:20am
If it starts that hard fix it
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:44am
hook a chain hooked to another and pull it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:50am
OK, 'show of hands' please...
How many guys still hand crank a mag equipped 'B' ?
I'm thinking there can't B too many.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:56am
I don't hand crank nottin' wit' ma' bum shoulder.......All my Tractors are equipped with Starter motors. Turn the key, listen to it wing over, and zoom, zoom. Ready to go ta' work!
Steve@B&B
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 9:09am
I hand-crank a number of mine that don't have provisions for a starter, including a wartime B (no electrical installed).  My 13 year old son starts them too.  Definitely not as easy as hitting a button, but it seems to me that if they're in good shape, hand starting isn't that bad - just a few lifts of the crank - no spinning.  I'm sure I'll reach a point in my life where I can't do it anymore, but for now, I'm content.  Not saying I've never flooded one and had to break a sweat, but once you learn what they like and dislike, it goes better.
I second the suggestions of, if you want a starter, install the right setup.  Seems a whole lot safer and more reliable.  Belt pulley starting does work well too, if you've got one that's stubborn or that you're trying to figure out.
Edited by GreenOrange - 21 Jan 2021 at 9:15am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 10:06am
I crank start quite a few of mine as they are only equipped with "armstrong starters".  '39 B, '28 20-35, '21 Twin city, '26 Twin City, etc.  They usually all start on the second pull of the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 12:45pm
Over on "Yesterday's Tractors - Tractor Talk"  there is a discussion and pictures of an electric starter for small planes. It would be fun to convert that over to start a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 3:03pm
Some people would just rather *!$$@* rig something that use bolt in parts to accomplish the same thing if it involves spending a few bucks.  A tractor that hard to start needs to be owned by someone that lives in West Virginia where's there's no shortage of a hill to park it on LOL  I've been hand cranking a B since I was about 10, that's more than half a century now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 3:26pm
wanna have real 'fun'.... flip over the prop on a float plane roped to a floating dock when a )**%^*(( big boat goes by.....Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 4:11pm
I did.
Later.
But I needed it to run TODAY, and it takes longer than one day to do an overhaul. For me anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 4:36pm
Jay
There is a non-starter B on our local Craigslist (Spokane area) that is causing me to break a couple of commandments right now; there is just something elegant about a Model B that is not cluttered up with all of those superfluous electrical gadgets Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 6:45pm
Just park it on a hill, like the way you'd start an old VW. With B's you have to have the mount while moving thing down pat, though...Wink
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 10:05pm
My 39 b had a newer torque tube installed with a starter. I had the starter rebuilt to 12 volt. It works well for me.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 10:34pm
I started my C for years with the hand crank. I didn't use the tractor much after I bought a CA and it always had a dead battery. Turn the switch on full choke pull through once choke half way pull once and it started every time. I did rebuild the mag and carb. I also hand cranked the WD many times if there properly tuned it just takes a firm pull and they'll start right up. The impuls coupler in a Mag makes hand cranking easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2021 at 10:11am
i like the  belt  pulley  idea  i have  the  pulley and  belt,  and  a wf  would be  easy to do  .   thanks  for all the  ideas
deas
This page was generated in 0.107 seconds.
