Seed Firmers
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: Seed Firmers
    Posted: 12 Jan 2021 at 9:08am
How many of you all run seed firmers on your planters? Do you like them? Are they worth the time and money?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2021 at 7:40pm
my seed firmer was on my press wheel, a single rib down the middle.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2021 at 8:11pm
I have them on my Deere 7000, not sure how much good they really do. They were on there when I bought the planter.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2021 at 9:30pm
Older IHC planters and JD vacuum they help with seed bounce, no help to white and not sure about Kinze.  Problem is if you worried about seed spacing they can screw with that.  Had them on JD haven't had any since been running a 8516 White.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 7:25am
We've run them for years. Ran them first on deere 7000 and now on Kinze 3600. Seems to help keep the seed a consistent depth.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 8:10pm
I’m a huge believer in them. EVEN seedling EMERGENCE is the primary goal of a seed furrow firmer. Yes, they may slide a seed now & then which does antagonize seed meter & seed tube singulation efforts. Aside from a few misplaced seedlings, it’s more important to achieve EVEN SEED FURROW DEPTH that allows for the beginnings of even emergence.
