Lets see your snow moving machines!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: Lets see your snow moving machines!
    Posted: 05 Jan 2021 at 7:18pm
Lets see your snow moving mcahines!
Here is my Series 1 D17 with a three point blade. Works good!
Mike Townsley in Iowa
Edited by allischalmerguy - 05 Jan 2021 at 7:20pm
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 7:27pm
My AC's hibernate waiting to see their shadows
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 7:32pm
My C with her 7' poly plow.  She loves working in the snow!
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 7:34pm
This yamaha rhino is a ball to plow with too.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 7:41pm
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 8:24pm
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 8:36pm
WD45 with snap coupler blade. TL12 loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 8:51pm
Is your TL12 4 wheel drive?             MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 9:05pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 9:13pm
No pics of the 200 with the snowblower but I've got a video from inside the cab from last January. Not enough to bother here yet and if there were enough snow my neighbors or a cousin or two have all volunteered to plow my place until I'm well enough to do it on my own which hopefully will be soon.
[TUBE]sFwseYJfAX0[/TUBE]
Edited by Lonn - 05 Jan 2021 at 9:15pm
Wink
I am a Russian Bot
190xt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 9:18pm
garden_guy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 11:30pm
I feel like I am underpowered here, lol.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 12:41am
My usual one I've been using for years.  Although I did use the D14 with the back blade a couple times this year.  If I need to use it much more I'm gonna need to get chains for it.  The wheel weights just ain't making it any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 3:34am
i ain't gonna show ya'll a pic of the "machine", then ya'll will know what to look for when you come visiting! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 6:09am
It is supposed to be, but the rear axle is missing all the internal parts. That's why the chains are on the front axle. I figured someone would notice. Still on the hunt for the parts to make it work.
It is a bit overkill for my yard. I only have a 20x30 area to clean, but I often clean half the neighborhood. Use the tractor and blade to pull it out into a pile, and use the loader to carry it to the pile at the end of the street.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 7:28am
My TL10 don't have enough traction to fill bucket.               MACK
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 8:59am
I'd post a pic but you already know what a snow shovel and bad back look like. Tongue
John, I have an Ingersoll 4020 with a front snowthrower. Works great, but I don't use it much since most of our snow removal is done by plow truck and the cleanups with shovel and snowblower as appropriate.
For those wondering why I used both "snowthrower" and "snowblower," GENERALLY a snow thrower has an impeller (expeller) integral with the auger while a snow blower uses an impeller separate from the auger. Semantics, I know... The Ingersoll has an integral impeller, the 3 snowblowers a separate impeller.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 9:14am
I use my 1952 WD as my snowblowing tractor with a 6 foot 3 point blower. I converted to a 12V alternator to run good Halogen lights and it does great. Has saved my neighbors several times in big snows and we typically get a lot of snow here.
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 10:08am
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 10:29am
I know it's the wrong color, but it fits in my heated shop and does a pretty good job.  At least the rear weights are Allis-Chalmers.
The pictures are few years old... don't pay attention to the old beer box in the background.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 11:42am
Will, that appears to be a 6080 FWA? Beautiful tractor.
Mike R. in Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike R. in Maine Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 12:08pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 12:24pm
This is an older pic. I unfortunately no longer have the black helper any more!
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 12:50pm
Won't post them since their green. Only had to use once so far. We have a few AC Garden tractors with snow blower, blades and a gas powered walk behind blower but haven't used for years. Easier to do with big tractors.
nick51ca View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote nick51ca Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 1:03pm
omahagreg View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 3:29pm
Nick, that front mount on your CA is SWEET!
Greg Kroeker
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 3:59pm
Does my dually and 5th wheel camper with Port Lavaca Texas on my mind count as snow removal equipment?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 4:49pm
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 6:09pm
This is my snow moving machine in Belmont, Michigan.  Eventually I will be adding the power steering unit that I have for this 919H
Edited by snowman(MI) - 06 Jan 2021 at 6:12pm
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Unit3 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 6:15pm
If I had to judge this contest, I would have given the price to the 6080 FWA, until, until the mighty CA with the front mount snow blower showed up. That is wicked way cool.
