7045 Crank Broke - Rebuild or Swap?
AllisHunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Crank Broke - Rebuild or Swap?
    Posted: 31 Dec 2020 at 6:43pm
I know this has been discussed many times but wanted any new opinions I could get. The crank in my 7045 is broke. What’s everyone’s thoughts on rebuilding or replacing with another 426 vs a swap of a Cummins or something similar? This is my main tractor and will be for a few years. I want something I can depend on as much as possible. Thanks and happy new year!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 7:33pm
I'd find a new or good used crank, bearings, gaskets and go with it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 8:12pm
Had the engine been overhauled before?
Wink
I am a Russian Bot
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 8:43pm
Replace the crank and overhaul while you are at it.  Then you know what you have.  Buying a used engine Allis or other brand is a crap shoot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 9:05pm
I don’t know forsure. I just bought the tractor with the understanding something was off with the motor. I knew it was a gamble but I didn’t plan on the crank because it seemed to be running well. The way the oil pan gasket was on, I think it’s been off before. The crank broke in front of the number 1 cylinder which seems kinda strange.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 9:32pm
Is the crank damper pulley real bad? I remember a 7080 that did that exact thing in the Allis shop the few years I worked there back in the early to mid 1990's. New crank and bearings and what not and it went on it's way.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 10:20pm
I don’t know honestly. My friend that’s helping me with it said he was really surprised how it was broke and wasn’t sure why it would do that.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 8:11am
Might have been overhauled and the block wasn't line bored, therefore the crank wasn't in there square.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 3:29pm
A 5.9 cummings would be cheap compared to rebuilding the 426 and it would also have more power and be rock solid dependable. However fixing the Allis motor would retain it's value.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 4:04pm
Give me a price for a 5.9 Cummins that will make 170 HP at the flywheel. New or used or whatever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 4:09pm
Good call, as it would not be price comparison in no way -
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 4:26pm
I've looked around a little and cannot seem to find anything OF THAT HP RATING for less than $4500 used. Then you have the custom backplate and flywheel/torque limiter connection and keep adding on from there.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 5:05pm
unless one is doing the labor and not figuring and labor cost - I think one will find the labor + adaptor stuff will = the price of that engine... we have done 3 , on deutz and 2 Cummins... unless one has a complete kit - figure 30 hours... min,,, adaptor, flywheel, torque limiter, fuel lines, front motor mounts, rear plate, AC - radiator hook ups , alternator and wiring throttle controls , exhaust system, mating intake from air filter... and probably 10 other things I forgot.    I would shop for a salvage 426  form a L or N and swap out the front cover, pulley === probably less hours than a tractor motor.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 5:56pm
Just WHAT makes a crank break ?? the crank in the XT snapped in 2 18 years ago while pulling a 12' disk AFTER pulling a 5/16 moldboard plow (hard) ConfusedConfused ?? Thankfully dad had a qualified Allis dealer to make the repair Wink !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:03pm
I have one I'd sell for $2500 Drove the truck home then parted it out as the frame was rusted. About 220,000 miles Advertised by Dodge @160 HP a little tuning and 200 isn't a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:05pm
But, that truck engine doesn't have a variable speed tractor governor?? correct  ??? I see it has an air-to-air aftercooler, which wouldn't really allow 200 HP in the tractor chassis without it, maybe not even allow 160 flywheel HP without it ??
Edited by DrAllis - 01 Jan 2021 at 6:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:20pm
I've never seen an XT turbo diesel crank break, but my crankshaft grinder is extremely anal about how to actually grind a crankshaft and making the radius grinds perfect. A good deal of crank grinders don't understand that and grind the corners nearly square and then down the road, a crank may break. A good friend of mine, who was an old AC dealer had multiple XT cranks break over the many years he was in business and figured out it was his machinist who was causing the problem. Some crankshafts should NEVER be reground undersized because they have been gotten hot from a bearing burnout. Whenever that happens, the crank is usually junk even tho it may magnaflux OK for cracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:36pm
Until the crank breaking, that was the first time the engine was opened up since the factory closed it up Wink. Yes, a new crank was installed at the dealers shop back then .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 7:12pm
Then, your failure was due to a bad crank pulley damper or a bad piece of crankshaft steel. Line bore probably wasn't the issue unless the repairman had it line-bored while apart.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:44pm
Dr Allis is correct about how important the fillet radius is as far as crankshaft strength.
 When I worked for the Allis dealer many years ago (I started my own shop in 1976) I had a 190XT break a crankshaft within a year or so of rebuilding the engine and having the crankshaft reground. I remember reading in the AC 190XT manual (after the failure) a warning along the lines of " when regrinding the crankshaft, do not decrease the fillet radius or crankshaft breakage can be EXPECTED".
Edited by pirlbeck - 01 Jan 2021 at 11:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 1:32am
My 8070 manual is very specific about journal fillet radius...even diagrams it for the slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 9:20am
Originally posted by DougG DougG wrote:
Ive heard the term -fillet radius- just dont understand what that means , could someone explain ?
It is the radius of the transition area from the crankshaft rod or main bearing journal (bearing surface on he crank) to what would be the vertical or thrust portion of the crankshaft.
Here is a link to more info.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 11:10am
IMO basteredized 7000 series have even less value regardless if the new engine is supposedly better or not. Myself, at auction, I'd pass and look for something else.
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 11:40am
A 5.9L swapped into a 7000 series would likely add value. The VE pump on the Dodge pickup engines do indeed have an excellent variable speed governor. There's a 2-155 White around here locally with a 5.9 swapped into it. It is a 175 flywheel hp industrial engine that is intercooled with jacket water. Driving that tractor, you'd never know someone took a 478 out and put a small 359. The 5.9 Cummins is a great little engine than could lol! That white puts out 175 on the pto too by the way.
To the op, I'd get it apart and see what you need, and then get another 426 to get it back together. The 5.9 swaps are nice, but it's a very expensive route! A 426 is a great engine.
Edited by injpumpEd - 02 Jan 2021 at 11:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 2:28pm
The NON aftercooled 5.9s (89-90 and later automatic equipped trucks) were also rated at 160 HP. I have one. Then as EPA demanded the fuel was cut back and timing retarded for truck engines, thus the aftercooler brought them back to 160 rated HP, as this 93 I have available engine is. Now turn the screws  and roll the pump towards the head an WaLaa , your back to the 200 HP area.  Then the next step is the P7100 pump and 250+ even 300 is doable and they will live, even 400 is possible as a turn the key and it goes (and goes and goes and goes...) engine. Unlike a lot of engines that become a time bomb when turned up. They just take a bit more fuel to do that without affecting durability.
 Allis Hunter was just asking for opinions on what was possible that would be dependable.
  Dr. Allis just implied that 5.9 engines were not available at a reasonable price, no dis-respect, but they are out there. You can buy rusted out 1st generation trucks and have a low cost repower, if you choose to go that route.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 2:56pm
The 7045 crankshaft- is it cast or forged?
If cast, is it cast iron or cast steel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 4:11pm
I've never seen a diesel crank that wasn't Forged Steel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 5:05pm
Well Paul, I said I'd looked around a little, not a lot. I still maintain the total cost to convert to a 5.9 Cummins could well exceed just fixing the 426. I'm not a Cummins hater, just hate to see people led down a path of  "it will only take X amount of dollars" and then get to the end and find it turned out to be quite a bit more than the originally quoted "X".  Tbran gave some good advice, as they have actually done a few. Happy New Year.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 6:59pm
Friend of mine has a complete N5 engine for sale. $2500.00. Central Iowa location.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 7:04pm
    I wouldnt drop down in cubes to 360, no way.
