WD gauge pod paint
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD gauge pod paint
    Posted: 13 Dec 2020 at 7:31pm
Do I paint inside or leave bare for good ground?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 8:10pm
I wouldn’t Matt. As a matter of fact I would take a wire brush and make the metal shiny at all contact points. The small screw at the lower left of the cover is a really important area that needs to have a good ground. When I disassembled my 190XT and painted all parts separately I had to go back and scrape paint to get my grounds back in order for my lights to work. What a nightmare especially with 4 coats of PPG on them.. they built them and then painted the tractors. I noticed this when I took it apart, bare metal behind fender mounts. Makes sense now lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 8:14pm
Thank you sir I still need you to fix the brakes on our 190!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 7:15am
Would be glad to Matt if you were not 3 hours away lol! Not too bad of a job if you spin the wheels out. If you wanna haul it up to my place I would be glad to to do it for you. How bout them Hokies? Commonwealth cup is back in Blacksburg where it belongs!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 8:28am
When repainting your Tractor, (especially the early model years with 6V systems) its best NOT to paint the inside of the instrument boxes. The early model Tractors with their 6v systems and three position charging switches need the grounds in order to work properly. Paint is an excellent insulator.  Alternators get their ground through mounting brackets to the engine block. Voltage regulators get their ground through the chassis of the unit to the sheetmetal or whatever it's bolted or screwed to. With lotsa' paint those grounds can't be achieved and all kinds of goofy stuff starts happening to the electrical system while its searching for grounds. Charging is one of the big problems with lack of grounds. Flickering lighting is another issue.  Just keep in mind, grounds are just as important as the feeds.  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 8:47am
Adding ground wires easily overcomes grounding issues with painted parts and they don't give rust a place to start. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2020 at 9:11pm
If your trying to keep originality that doesn’t look to good, but your correct it will work.
