Valve grinding
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Valve grinding
    Posted: 03 Dec 2020 at 6:05pm
Was gifted an Allis B with the head off, appears to need the valve seats and valves ground, do you fellows repair heads yourselves or send them out.  The last one I sent out 5 yrs or so ago cost $180, would like to hold the expense down on this tractor, as I know of other work it needs.  Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 6:10pm
you could try lapping and see what it looks like.. Maybe dont need recut... If you dont have a lapping tool, i have used a 1/4 inch rubber gas line pushed over the valve stem, the a 1/4 inch stud in a hand drill and push the hose over it.  put lapping / grinding paste on the valve, oil the stem, push in the hole and connect to the drill..... bump it slowly so it rotates and  grinds/ laps the seat... you dont want to go FAST or run the stem dry of oil... Do it slowly for 2-3 minutes and inspect you work........ Its not rocket science, just a slow speed, low HP motor.. Dont have to be perfect, if your on a budget.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 6:41pm
Thanks Steve, I'll try that, the #4 exh is pitted so may take some time on it.   Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:08pm
some will tell you that you cant do it this way. I dont think i would do a high HP truck and want it to last 250,000 miles, but thats not what your building... Go to the hardware store and get some COURSE grinding compound and do that.. You might spend a half hour on a BAD valve.. Just go SLOW and keep oil on the stem.. You will be able to tell after a few minutes if the seat it trashed to the point that it will never cleanup.
Edited by steve(ill) - 03 Dec 2020 at 7:19pm
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:27pm
Check the head to see that is flat and that it doesn't need to machined. Before doing all that work. If have to send off for that
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 8:57pm
Just tighten the chuck to valve stem . No need to mess with a Rubber hose that will twist and come off.        MACK
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 9:53am
x-2 on chuckin the stems in drill! -- done many that way in a hurry. I now have an old grinder so I run them thru it now.
Head grinding is the other problem!
jlbintn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlbintn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 11:23am
I don't have the expertise, or the tools, to do it myself. I sent my head to a shop, seven weeks and $276 later, it's good to go. The valve kit was another $120, so almost $400 into the whole repair, but it's done.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 2:28pm
I lapped the ever-lovin' bejeebers out of my B's valves, most especially from the 2 cyliders which had rusted and locked up the engine.  I figured I would try to get it running and if needed a real rebuild, I would cross that road when I got to it.
Well, 3 years later, she's still running like a champ.  No rebuild yet.
I wish I had pictures of the "before" lapping.  There was slight pitting on the seats for one cylinder (both valves) and moderate pitting in the other cylinder, but both seal up and make decent compression.
[TUBE]kv-HXI-r3eM[/TUBE]
Edited by HoughMade - 04 Dec 2020 at 2:31pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 3:49pm
YEP... your not building a race car.. Just the basics and it will run fine !
