I-600 trans and rearend?
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: I-600 trans and rearend?
    Posted: 02 Dec 2020 at 9:07am
I have a I-600 and the rear end is going out the trans jumps out of gear  I want to unbolt the tractor from the tourque tube and replace from a donor tractor  which has been done in the past as I have a yellow from half and a orange rear  what donor tractor do I need the d-14 or the d-15?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 9:08am
and yes its a shuttle shift  the best loader tractor ever!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:56am
Either a D14 or D15 will work. I put  a D14 transmission and back on a D15 diesel. One gear part number was different but the D14 part number was upgraded to the D15 number. Simple bolt up.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 9:21am
Might wanna take the donor apart and replace the brakes while it's easily accessible.
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 10:24am
I have a few I 600 parts tractors. Ryan 402-469-1738
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 6:12pm
I would take the side cover off the doner and carefully examine the shift collars or you may end up replacing bad parts with more bad parts.
