Wheels for WD45 |
groundhog55
Topic: Wheels for WD45Posted: 02 Dec 2020 at 7:44am |
Is there 5 bolt wheels anyplace that fit a WD45 for 7.50 tires? If not is there a 6 bolt hub and bearings that will fit?
DrAllis
Posted: 02 Dec 2020 at 9:08am |
50 years ago, my Uncle had some Buick or Pontiac wheels with wide tires (9.5 L x 15?) that fit on a WD45 wide front. So, yes, there used to be a GM wheel that fit the 5 bolt pattern and was wider than an AC wheel.
orangereborn
Posted: 02 Dec 2020 at 9:30am |
x2 on the Buick....I have seen others with center hole rib trimmed out that fit also. In fact I think I could get you a pic of that.....Dale
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 02 Dec 2020 at 11:43am |
5 x 5 bolt circle. Chevy pickups 71-90's had the pattern.
Joe(TX)
Posted: 02 Dec 2020 at 1:42pm |
I measure the WD45 wheels. They have a 3 3/8 center hole. The Chevy pickup wheels have a 3 in center hole.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4193 |
Posted: 02 Dec 2020 at 2:23pm |
Here's a couple shots of my 45, one with the Buick rims/9.5Lx15's and one with 7.50X15's on 6 bolt wheels. I did a project thread on here about converting to 6 bolt. ![]() ![]() |
NE GA Allis
Posted: 02 Dec 2020 at 7:29pm |
if you get the chevy 5x5 bolt pattern wheels, you can cut the centers out larger to fit. Did that a time or two and worked great!
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
groundhog55
Posted: 03 Dec 2020 at 7:31am |
Where is the thread for the six bolt hubs?
IBWD MIke
Posted: 03 Dec 2020 at 8:58am |
Note that this is just how I did this. There were WC's with six bolt hubs that may work, don't know. This was not a cheap endeavor! I do really like the results though.
