L2 concave 9 bar vs 7 bar
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Topic: L2 concave 9 bar vs 7 bar
    Posted: 30 Nov 2020 at 12:50pm
Does anybody have any experience with the aftermarket 9 bar concave vs the original 7 bar? are the bars closer together or does the open section extend further back?  Curious on the performance of the 9 bar in wheat.  Thanks Kevin
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2020 at 10:16pm
I put the 9 bar Lowen in my L3 several years ago with new bars, got them from Abiline Machine IIRC,,,I think the 2 extra bars extended further back than a 7 bar.
 but  man! what a difference!!,, it was a total different machine!, I run 1/8"-1/4" clearance, ~600-700 cylinder RPM, done excellent job of thrashing with little to no cracking. I have not run this in corn, the concave wires are closer togrther, so not sure how well it would work in corn, I do believe Lowen makes a different concave for a corn/wheat application,,, but I'm not sure about this...
sunnybrook is what Gleaner carried,, and they had a 9 bar also,,, I think.....
If your only doing wheat,, I don't think you can go wrong with the 9 bar...
Edited by Michael V (NM) - 01 Dec 2020 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 10:05pm
Thanks for the info Michael, I found out that Sunnybrook has them in stock, so I think I will give it a try.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 7:04pm
Any updates from anyone else on the 9 bar?
Always been OEM style 7 bar here, about to pull the trigger on a 9 bar for a customer and wanted to get some more input,figured I'd add to this thread rather than start another.
Luckily he is almost all small grain with it, so I'm going to say he "should" be happy, just double checking. :)
Edited by GM Guy - 15 Jun 2021 at 7:15pm
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 8:39pm
Here’s the AGCO (Sunnybrook) website, that discusses this concave. It reads that two spacing are offered 1 & 2”, so grower will need to decide which spacing is best for their conditions??
“Gleaner
Models L & M Conventional:
All concaves manufactured for these models are heavier than original equipment. Two extra threshing bars have been added to increase threshing and separating ability. In addition they are precision line-bored to ensure a perfect circle and fit, and have four removable filler plates.
Two wire spacings are offered. The 1” spacing is more common since the 2” spacing is effective only in cereal grains with large amounts of straw.”https://www.agcopartsandservice.com/content/dam/agcopartsandservice/NA/Combine_components_reference.pdf/_jcr_content/renditions/original
