Allis B with a cab |
Post Reply ![]() |
JD-Ohio ![]() Bronze Level ![]() ![]() Joined: 22 Oct 2009 Location: Columbus Grove, Points: 39 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Nov 2020 at 7:50am |
Can anyone remember a post on the forum in the past about a city that had B's with a cab and plows to plow sidewalks? Would like to see those pictures again. Thanks for any help finding those pictures again.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54169 |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87966 |
No data, just photos.... on the IBs, i think the door is normally in the BACK
![]() ![]() Edited by steve(ill) - 27 Nov 2020 at 8:42am |
The 1941 version may not have had a door.. I seem to remember a discussion that the back end was open, no door. .... I think these were in NYC if i remember right.
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
I have a restored IB with an enclosed cab and a snowplow. I'll post pix if I can figure out how to do it.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
resize your pix. in paint to 640 x 480 and they will go right in.
couple more photos.......
this one is different Edited by steve(ill) - 27 Nov 2020 at 6:24pm |
Just a thought.... on an IB, you get on from the BACK... On a B or C you normally bolt a step in the FRONT onto the 2 x 2 box section that holds the brake pedals to get a leg up.
What if you bolted an angle iron to the bell housing bolts and dropped down, then used a section of grate maybe 12 x 24 and ran back toward the brake pedals, about half way up ( 16 inches off the ground)... This could be your STEP UP.. Now your within a step up to the platform area.. Put the door in the front at the end of the GRATE and step into the cab. ![]() |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I'm not to sure those B's would have had the foot brake conversion that far back. I think they came around quite a while back. Bill can probably remember when they originally came out with them. We always stepped on the drawbar, then on the tire them over the fender. That just seemed like the normal way of getting on a B, C or CA. |
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
John, The foot brakes came to the B-C about 1942. You know, today I do not believe I could mount the B without an implement to step on or an assist.
I do remember getting on them the way you describe. Good Luck! Bill Long
What difference does it make where the brake pedal/ lever is ?? Put a step on the front and you will see a big difference. Lot easier to get on and off a B or C.
Edited by steve(ill) - 27 Nov 2020 at 10:00pm |
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
We all ways got on the B from the back till I mounted the saw rig. Need to make me a step to make getting on from the front easier. Was looking at it yesterday and was thinking I would have to make the cab come out from the tank over in front of the tire in order to get a door wide enough for my large frame to get through easily.
jlbintn ![]() Bronze Level ![]() ![]() Joined: 28 Nov 2019 Location: Charleston, TN Points: 138 |
Those look pretty cool, but hot damn, it is a minor gymnastics event getting on an open B, and I am not a big guy ![]() |
Post Reply ![]() |
