Cylinder sleeve O ring lube |
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Topic: Cylinder sleeve O ring lubePosted: 18 Nov 2020 at 3:24pm |
I'm sure it's been posted here but I don't recall the answer. What do you recommend for lubricating O rings when I install new sleeves. Thanks
Bob@allisdowneast |
I used to think I was indecisive, but now I'm not sure.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5909 |
Posted: 18 Nov 2020 at 3:47pm |
I think most use plenty of liquid hand soap. Dry fit them first without 'O' rings. When I use to fit them dry, I put a piece of masking tape inside the liner at the front when I found the ideal location. Press the liner in with the palm of your hand , turning the liner at the same time. Worked for me. |
Bob-Maine
Posted: 18 Nov 2020 at 3:52pm |
Thanks, Gary
Bob@allisdowneast |
DrAllis
Posted: 18 Nov 2020 at 4:46pm |
Mazola cooking oil or the like. Wipe the inside of the lower block bore with it and rub some more all over the Orings on the sleeves. Push them home and use a bolt and flat washer to keep them sunk clear in until you're ready to install the cylinder head.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34855 |
Posted: 18 Nov 2020 at 4:48pm |
Built many wet sleeve engines over the years, Best lube that will not affect Sleeve seals in any way, Crisco.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 18 Nov 2020 at 4:51pm |
Pick your brand....vegetable oil liberally applied,not soap
DrAllis
Posted: 18 Nov 2020 at 5:53pm |
I use Crisco at work because that's what they have. It works just as good as the Mazola oil.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3987 |
Posted: 18 Nov 2020 at 8:16pm |
i have used dish soap , vegtible oil ,antifreeze, white grease, over the years got to be carefull you dont waste time with antifreze because it will make some o rings swell , but right now i have a bottle of, john deere 308 o ring lubricating soap . seem s to work good but it was about $25.00 a bottle, but i bet it lasts for 25 engines
HD6GTOM
Posted: 19 Nov 2020 at 12:17am |
Gallon of Rubber lube at NAPA was $13.95 2 weeks ago. NAPA calls it Ruglide. And you can use the rest of it fixing tires.
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 19 Nov 2020 at 7:29am |
only thing i use anymore is the john deere 308 o ring lubricating soap, decent sized bottle last quite awhile
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Bob-Maine
Posted: 19 Nov 2020 at 7:32am |
Thanks to all for the good advice. Bob@allisdowneast
