Identify This Tractor |
Les Kerf
Topic: Identify This TractorPosted: 17 Nov 2020 at 3:02pm |
I am not knowledgeable enough about A-C's to know what model this is https://spokane.craigslist.org/grd/d/chewelah-allis-chalmers-tractor-with/7213481656.html
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Posted: 17 Nov 2020 at 3:22pm |
It's an early D-17 that needs some TLC for sure but if it runs good, price is not out of line, rear tires don't look too bad.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
Les Kerf
Posted: 17 Nov 2020 at 3:35pm |
Can you tell if it is a gas or diesel engine?
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 17 Nov 2020 at 4:11pm |
Gas
Les Kerf
Posted: 17 Nov 2020 at 4:24pm |
Thanks for the replies.
I (my Wife actually) inherited two tractors, a WD and a WD-45, both with stuck engines. I drove the WD quite a bit some years ago, but when I got my own compact tractor I never needed to borrow it anymore, so it sat and got stuck. I tried all of the various snake oil remedies and hung 100# of weight on the crank handle all last summer, but to no avail. Either tractor will require $2000+ at minimum to overhaul, and that is with me doing the work. Just weighing my options as a running tractor for $2000 may be a better plan. Thanks again
jon
Posted: 17 Nov 2020 at 4:36pm |
Believe it is a D15 or D14. The dish in the rear rims is wrong for a 17. Also one of the pictures from the rear shows a curve/ bent gear shift.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11781 |
Posted: 17 Nov 2020 at 4:48pm |
Not a D17, for sure. I’m leaning towards a D14, if the monocolor paint is original.
Edited by TramwayGuy - 17 Nov 2020 at 4:49pm |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 17 Nov 2020 at 5:06pm |
Look at trans and axle housings .14 or 15 My best guess is D 14 with narrow draw bar Vail
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54380 |
Posted: 17 Nov 2020 at 5:43pm |
1959 + D-14. JMHO, at this point. Looks like a 3 bar grille behind that bumper...
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5905 |
Posted: 17 Nov 2020 at 6:00pm |
I say D-14, no thumb Guard on Power Director Lever, dead giveaway not D-15. |
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1729 |
Posted: 17 Nov 2020 at 6:24pm |
dished wheel centers, bent shifter, D 14
phil
Hyperpack
Bronze Level Access
Posted: 17 Nov 2020 at 7:08pm |
looks like a D14 with a Paulson loader, I have the same tractor here in the yard
MACK
Posted: 17 Nov 2020 at 9:01pm |
It is a D14 and not a 3pt hitch. Wheels looks like it spent a life time in a cattle lot. MACK
shameless dude
Posted: 18 Nov 2020 at 2:23am |
yeah....where is the 3 pt hitch?
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4550 |
Posted: 18 Nov 2020 at 6:26am |
Early D-14 '57-early 59 pre black bar grill.
Les Kerf
Posted: 18 Nov 2020 at 9:29am |
Wow, you guys are good! :-)
So is a D-14 sorta like an enhanced CA? I own a C, and am familiar with the CA, but is the D-14 as good as a tired WD?
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 18 Nov 2020 at 10:28am |
Well, when the D14 came out dad bought the first one with 3 bottom plow and cultivator, traded in a C with an Oliver 2 bottom plow and a 2 row Cultivator, a rope controlled tumblebug, some old harness and other things I've forgotten as I've slept since. The WD will outwork the D14, but if you add a light spring to throttle rod and adjust the WD will keep up, ground speed wise, when plowing the same field, and the WD will pull better.
RMD
Joined: 07 Oct 2009 Location: Connecticut Points: 304 |
Posted: 18 Nov 2020 at 10:48am |
The D10/D12 are enhanced CAs. The D14/D15 are more in the category of a WD (but not as powerful as a WD45).
RMD
Posted: 18 Nov 2020 at 10:49am |
Well, there are 3 attachment points on a Snap Coupler hitch.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1284 |
Posted: 19 Nov 2020 at 6:19am |
This one has a Du-al loader. Edited by Nathan (SD) - 19 Nov 2020 at 6:20am |
