D17 voltage regulator
D17Milo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Milo Quote  Post ReplyReply Direct Link To This Post Topic: D17 voltage regulator
    Posted: 21 Oct 2020 at 8:47am
Just installed a new voltage regulator on my D17. It is set up for negative ground, how do I polarize it? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 1:04pm
Without the Tractor running, take a jumper wire, go from BAT to GEN. It will spark. Perfectly normal. After that fire up the Tractor...
Steve@B&B
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 7:49pm
So you converted your tractor to a alternator correct? Would the procedure be the same for a generator with positive ground? Thanks. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:05pm
Yup! Same procedure.
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:10pm
I thought one polarized a generator, but not a regulator. I definitely plead electrical ignorance, but what part of a regulator requires re-polarization?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17Milo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:35pm
Clap Thanks Steve it has been too many years since I have done this.
This page was generated in 0.087 seconds.
