B grinding starter
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Topic: B grinding starter
    Posted: 05 Oct 2020 at 10:54am
Getting close to having 2/3 of the tractor done.  Wiring yet to do, and some front tires on order.  Paint definitely needs some touch up.  The starter grinds instead of engaging the flywheel about half the time.  The ring gear has some wear, but its not awful.  Is there any other starter inspections/adjustments I should look at before starting to replace parts?
The original push button contactor on the starter was shot, so I added a remote start solenoid, and running on 12 volt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 2:32pm
Replace your ring gear and have the starter rebuilt as a 12volt unit. This slows down the RPM of the starter and will not tear up the ring gear.  Yea everybody, there are hundreds people that have 6 volt starters running on 12 volt for years without a problem, however this is the other side of the coin.  Doing the job right will make it last your lifetime.
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 10:16pm
At a minimum, convert starter to 12v (if it isn't already) and plan on replacing the bendix.  Amazing what a new bendix can do.
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 11:14pm
Paul is right on the money. Running 12V's through 6V field coils don't cut it. Makes the Starter motor violent. Cracked nose cones, worn out ring gears, and bent drives are just a few of the complications of that situation. I completely rebuild these Starter motors including a rewound Armature if interested. I also add a HD Starter relay so the unit gets full power and has a nice transistion to the flywheel ring gear. Eliminates the old rod n' switch issue also. Installing a key crank start Ignition switch takes that Model B out of the 40's and puts it in the 60's.  If you need a wiring system, I build them to. Visit our website. There's lots of information on 12V conversions and the do's and don'ts.
Steve@B&B
bb-customcircuits.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 5:55am
If you're going to replace the chewed ringgear or 'remove,rotate 60*,reattach', you should l replace the pilot bushing while the tractor's split ! And the throwout bearing.....
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:56pm
Take the flywheel off, heat the ring gear and it swells enough to flip right off. Turn it over and put back on. Now you're looking at fresh gears. Then with a 1/16" grind wheel on a die grinder cut the bevel on the teeth to the same angle as before only on the back side. This will allow you to run the same flywheel gear for thousands of hours more, and is not difficult at all to do. Works for me.    Leon
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 5:49am
What Leon said! Done that many times only I just used a 4 1/2" angle grinder and knocked the sharp edge off at the same as or as close as the original angle.
Edited by Dick L - 07 Oct 2020 at 5:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 5:53am
sigh, on my D-14 you can't reverse the ringgear.. there's a cast 'lip' on it....so either new from India via AGCO or rotate 40-60* and reattatch.
Jay
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 5:57am
Jay
If you were to do that, why wouldn't you turn it 45 degrees, which is halfway between the four TDC (compression) spots?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 6:09am
I don't know, to me if I did that much work in splitting the Tractor to do some upgrades, I would install a new ring gear not flip the old one around. Just seems to be more logical to me going through the motions to do the job. Do it right and forgetaboutit....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 10:22am
Thanks for the input, guys.  Last night I pulled the starter out of the C and tried it in the B.  Huge improvement, no grinding and sounds good.  Hadn't really noticed how bad the starter pinion gear looked until comparing it to one that wasn't worn out.  The C is still a salvage project and I hate robbing more parts, but looks like this will get me by for now.  Also built a hand crank last night and started it a few times that way...just in case.
The flywheel ring gear is still not in great shape, but I think the majority of the problem was the pinion.  Thanks for the tip on flipping or rotating.  I didn't realize that was an option.
Point taken on the 12 volt conversion at the starter.  I suspect that is the correct way to go, but it will have to go on the wish list for now.  I converted to 12 volt because the generator needed a complete rewind and the mini Desno alternator was cheap and easy, along with the idea of eventually getting some LED lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 2:45pm
Steve@B&B
 Some people are just CHEAPExclamation
Just remember that putting another starter pinion gear up next to a worn ring gear will ruin that starter pinion in time. Don't wait too long to fix things right or you'll have 2 starters with bad gears.
