Rehabbing Some Rim Clamps
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Rehabbing Some Rim Clamps
    Posted: 04 Oct 2020 at 8:23pm
Had a flat tire on the D-17 and the wheel (including all the  clamps) were in bad shape so I decided to fix up a new wheel. First thing was getting a set of clamps back in shape. Lots of hammering on the cam pin back and forth with lots of PB Blaster to get them all loosened up. Then, use lots of "Never-Seize" to keep them free for a few years hopefully.
I was able to salvage all the snap rings but one. I really lucked out here.......found a spring in my 50 odd year collection that happened to have the right diameter and wire size.
I was able to get five working well. I still have 9 left in this batch......one may still be salvageable and eight that are beyond "redemption".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 5:42am
hmm..looks like a good 'Winter project' already  1/2 done !!!
Reminds me I have 2 buckets full of D-14 clamps I'll have to 'relocate' from next door ,one day.... probably need a dang STRONG unmovable vise for that job...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 6:24am
A big vice, a big hammer....and lots of patience. LOL
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 7:25am
Did 4 this summer. Tied a piece of wire and hung them in the burn barrel, cooked until the fire went out. Came apart real easy. These were in sad shape, calcium had them locked up good. Found more in the iron pile this weekend, they will get the same treatment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 11:36am
Brian,
Nice work getting these operational again. The D17 will back in business soon!
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 12:33pm
We take the snap ring off and press the pin out. Usually comes out with a big bang, power wire brush,  some never sieze and you're good to go
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 9:18pm
I have 29 on the shelf all freed up and painted.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 7:21am
I have found an impact wrench handy also. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 8:21am
Dug 5 out of the scrap pile yesterday, one missing an eccentric. Four will get 'cooked' in the burn barrel and cleaned up, painted for future use.
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 8:30am
I used Ted J method - put them in wood stove (remove blocks and snap rings first) for several hours and let them cool naturally.  Afterward they come apart easily with a little lube and hammer.
I found new 7/8" external snap ring retainers at Do It Best hardware stores.  The assembly cleans up nicely with large wire brush on angle grinder.
1951 CA - 1944 C - 1949 B - Kubota M6800
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 8:49pm
Well, I don't have that big a collection! LOL
However, I did paint up four of them and mount them on my new $150 wheel.
Now, I've got to put together another set to fit my other $150 wheel and I'll be in good shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 8:55pm
[QUOTE=
I consider myself lucky in that I found just one coil spring in my 50 year collection that had the correct diameter and wire size......I'll get quite a few more "snap rings" at essentially no cost.
Edited by Brian G. NY - 08 Oct 2020 at 8:59pm
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 5:55pm
x2 on what Bob-Maine said. I clamp them in my vise, heat them with a MAP torch, apply lots of WD40, remove the retainer, put my trusty electric impact wrench to work trying to spin the eccentric pin, and drive on the back end of the pin with my equally trusty hammer. Rinse and repeat....usually a number of times. After a bit the pin starts to rotate and then comes out. After that it's clean up, paint and Never Seize!
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 12:42pm
Word of warning,,,,,,,,,,,DO NOT get anti-seize on the face of the block.  I learned the hard way.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 10:21pm
I redid mine with no problem for my wd45, I did put some PB-blaster on them for the quick lube but they wasn’t stuck.
This page was generated in 0.128 seconds.
