WD45 Starter
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Starter
    Posted: 28 Sep 2020 at 8:27am
Went to start my 45 Sat. and the starter went poof...
Pulled it and the Armature melted at 1 spot.
System is 12V ground, starter is 6v.
I see I can order a rebuild kit that has all new guts, still 6v though. I have yet to find a 12v one. I know Steve redoes these, but has anyone done it themselves? Looks like you just pull parts and replace them. Just don't want it to poof again...
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 10:12am
As close as you are to Mt. Jackson Va. Why don't you run it over to John Brillman, www.brillman.com ; ?  he's turned lots of 6volt starters into 12volt ones for me. and could probably either have the parts on hand so you could do it you self or do a quick turn around in his shop.
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 10:44am
I bought one of those eBay rebuild kits and installed in me WD. It was for 6 volts and I must say it was good quality and worked perfectly.  I will caution, soldering the new tap lug is not for the novice person!
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 11:22am
X2 on what Paul said.Not to take away from Steve but Only 20 miles away,I would have already dropped it off to brillman's Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 11:24am
Sounds Good
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 11:29am
34 miles! Ha!
I will drop it off this week sometime, thanks for the reminder for them.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 3:34pm
Let us know how you come out Charlie.  I've done a lot of business with them "Brillman Co."  which reminds me, I need to order some wiring kits for the CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 7:50am
Got my starter back. Looks new with a new tag. Performs as expected.
$318 was a bit steep but it should last my lifetime.
They are a big AutoCar fan if you didn't know. They have several old semi's sitting around.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 9:26am
For the money spent, I'm guessing  the starter was rewound for 12v ??If so ,money well spent.It will be much easier on the drive and ring gear now.Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 9:58am
Yes it was
Charlie
This page was generated in 0.773 seconds.
