r-5 gleaner unload auger wiring?
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: r-5 gleaner unload auger wiring?
    Posted: 25 Sep 2020 at 8:44pm
having an issue trying to get my unload auger to run  i put the test light on the center terminal of the switch and the test light barely glows rock the switch and nothing any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:37pm
Your Owners Manual has a very good electrical schematic of each and every circuit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:42pm
thank you i just dont understand why the low voltage it barely lights up my test light
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:51pm
Poor ground on your test light or mice have chewed thru wires somewhere. How long have you owned this combine and when did the unloader last work ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:57pm
ive had it for several years  last year it quit working so i just ran a jumper wire from the clutch to a battery pack and grounded on the door to unload it works i would just rather be able to use the switch
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 10:47pm
IF memory serves correct - there is a module - square with wires coming out the bottom - below the fuses next to the floor. It is a solid state latching relay. Check the connections and the GROUND. This is the same module used on the R40/50 and prone to malfunction when connections corrode.  71345084 worth checking.  Barring that... I have switched many over by installing another clutch switch in lieu of the momentary switch - using the power through the safety switch to energize a relay that sends power through it from the main relay to the clutch. .
